      • Coating Thickness Gauges
      • Hardness Tester
      • Rotary Workholding Kits
Compensating TSC Union Coolant Leaks
Service Home Service Updates Compensating TSC Union Coolant Leaks
February 21, 2020 Compensating TSC Union Coolant Leaks
This News has been posted for more than 90 days.
Be advised that the information displayed may not be current and valid. Service News information is subject to change.
If you have machines with TSC that leak coolant on top of the spindle motor, this can be caused by a damaged seal [1] in the TSC compensating union.
NOTE: This seal can be used on both 40T and 50T spindles.
Do not replace the union, instead order the TSC compensating union seal kit P/N 93-3179.
