      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
DS-30Y Sub-Spindle Drain Hose Location & Shipping Bracket Removal
Service Home Service Updates DS-30Y Sub-Spindle Drain Hose Location & Shipping Bracket Removal
June 03, 2020 DS-30Y Sub-Spindle Drain Hose Location & Shipping Bracket Removal
This News has been posted for more than 90 days.
Be advised that the information displayed may not be current and valid. Service News information is subject to change.
If you are seeing hydraulic union drain back problems or the hydraulic union leaking on a DS-30Y sub-spindle. Check that the drain hose is not damaged and is located in its track.
During machine installation, it is important that after removing the sub-spindle shipping bracket to verify that the hydraulic union drain hose is located in its track. If it is off the track, it can be caught behind the casting and damage the drain hose.
To remove the sub-spindle shipping bracket, follow the procedure below:
DS-30Y Sub-Spindle Shipping Bracket Removal
HS6NP, 2-1/2" Diameter Complete Shell Mill Kit, CT40 Holder, 4" Gage Length, Grade HN25, TSC $530.95 $451.97
9.5mm Ø Cobalt Taper-Length Drill, 135° Point Angle x 33° Helix, 2 Flute, TiN Coated - Pack of 2 $43.95 $26.97
