Axis Lubrication System Has Changed
ATTENTION! Haas Liquid Grease (HLG) cartridges and refills are no longer available.
Machines using HLG will need to be conveted to the latest axis autolube system (Autolube Retrofit Kit PN 93-3556) before your OM/OL will accept the replacement lubrication cartridges (cartridges may be oil or grease). The process is simple, and is a good opportunity to verify that the machine’s axis lubrication system is working properly. See the conversion kit and procedure linked below.
HAAS RED GREASE CARTRIDGES (93-1579) ARE NO LONGER AVAILABLE.
YOUR OM/OL MUST BE CONVERTED TO USE THE 93-1579A CARTRIDGES.
If your machine has not been converted to the latest autolube system, or if your lube system drive unit needs to be replaced, order PN 93-3556 AUTOLUBE RETROFIT KIT OM/OL. The kit includes a refill cartridge (cartridges may be oil or grease), a drive unit, a battery pack, and a mounting bracket.
ORDER YOUR AUTOLUBE RETROFIT KIT, PN 93-3556
If your machine has already been converted to the latest autolube system, and you need a refill cartridge, order PN 93-1579A REFILL CARTRIDGE OM/OL (cartridges may be oil or grease).
ORDER YOUR OIL CARTRIDGE REFILL, PN 93-1579A
Related Service Documents
Follow the conversion procedure below to properly upgrade your machine’s axis lubrication to the latest autolube system (cartridges may be oil or grease).
Haas Axis Lubrication Oil Conversion Procedure
  1. Haas Service Parts
  2. Maintenance
  3. Grease, Oil, & Sealants
  4. 93-3556
93-3556
93-3556
93-3556
93-3556
93-3556
AUTOLUBE RETROFIT KIT (OM/OL)
Part #: 93-3556
AUTOLUBE RETROFIT KIT RED TO OIL OM/OL
Price: 799.95 ( / unit)
Use this Autolube Retrofit Kit to upgrade your Office Mills and Office Lathes that were built before 12/2008 from the red grease to the latest axis autolube system. This kit contains all necessary components to install the lubrication system, as well as a refill cartridge (cartridges may be oil or grease).
SAFETY DATA SHEET
93-3556
93-3556
93-3556
93-3556
93-3556
93-3556
