      • Coating Thickness Gauges
      • Hardness Tester
      • Rotary Workholding Kits
OM/OL - Autolube Retrofit and Replacement - AD0665
Service Home How To Procedures OM/OL - Autolube Retrofit and Replacement
Recently Updated Last updated: 03/26/2024
AD0665
- Jump to Section - 1. Introduction 2. Retrofit Kit (3 steps) 3. Replacement (2 steps) Back to Top
Office Mills and Office Lathes from 2008 and earlier use an autolube system, the old system and lube cartridges are now discontinued. This procedure shows how to retrofit the system and how refills work.
This procedure applies to the following procedures:
  • 93-3556: AUTOLUBE RETROFIT KIT RED TO OIL OM/OL
  • 93-1579A: OIL REFILL CARTRIDGE OM/OL
Note: The images show oil but the cartridges that come in both kits will work whether it has oil or red grease.
Retrofit Kit
First remove the old autolube system.
To retrofit the autolube system order kit 93-3556.
Next remove the cap [1] and place the batteries [3] in the drive [2] and screw on the lube cartridge [4].
Remove the lube plug from the lube cartridge and attach the lube retaining valve [2] in its place and attach this back to where the old cartridge was.
The new bracket [1] is backwards compatible with the old mounting locations and can be attached using the hardware [3].
You now need to select the lube cartridge size and the discharge period.
Do the following steps:
  1. Press and hold the set button for at least 5 seconds
  2. Release the set button.
  3. Press the set button twice to select LC 120, it should have the bar in the middle as shown.
  4. Wait at least 3 seconds and now you will set the discharge period by pressing the set button until the screen says 12. After this make sure to wait at least 3 seconds to ensure the discharge period is set.
  5. Press the set button and the cartridge should start running, the screen will read 'ru' when it is running.
Replacement
The lube cartridge should be replaced every 12 months, order kit 93-1579A.
The replacement kit will come with a lube cartridge and batteries, the batteries are not rechargeable and must be changed every time the lube cartridge is replaced.
Replace the lube cartridge and batteries.
