ROBOT CELL ACCESSORIES
HAAS TESTED. HAAS PROVEN.
  2. Automation Accessories
  3. Robot Cell Accessories
Robot Cell Accessories Overview
______________________________________________
Adjustable Height
Stand
Our adjustable-height stands are your solution for achieving the perfect positioning of your cobot. With an adjustable height range from 24" to 36" (610  to 914mm) in 2" (51mm) increments, you can tailor the height to your exact requirements.
  • Height Range: 24" to 36" (610 to 914mm) in 2" (51mm) increments
  • Achieve the precise height for your cobot with ease
  • Height adjustment and leveling hardware are included
Table & Templates
Our cobot part tables are designed to accommodate different-sized templates for staging raw material and finished parts. Each part template accommodates a variety of part sizes, features an accurate grid pattern, and includes solid hard stops to ensure repeatable part locations and reduce misloads.
Robot Pallet
Loading System
Enhance your productivity with our zero-point robot pallets and pallet holders, designed for use in the Robot Pallet Loading System. By adding additional pallets into the system, you can effectively produce more parts and maximize machine output while minimizing downtime. These robot pallets streamline operations, ensuring a seamless workflow to keep your processes running smoothly.
Part Flip Station
A part flip station adjacent to the parts table provides a convenient location for the cobot to place parts and then regrip (flip) them for machining the other side, to simplify 2nd-op automation.
