      • Fiber Laser
      • VF-4SS
      • 00-0012
TL & CL TOOLHOLDING
HAAS TESTED. HAAS PROVEN.
SEE ALL TL & CL TOOLHOLDING
  2. Lathe Toolholding
  3. TL & CL Static Turning Holders
TOOLROOM LATHE AND CHUCKER LATHE TOOLHOLDERS
TL Toolroom Lathe and CL Chucker Lathe Toolholders
When you need toolholders for your Haas CL-1 Chucker Lathe or TL Series Toolroom Mill, HaasTooling.com is your best source. The CL-1 comes standard with an 8-station automatic tool turret that accepts standard gang-style tooling. The Toolroom Lathes are available with the same 8-station turret, or a 4-station turret that accepts 3/4" (20 mm) turning tools.
4-STATION TOOL TURRET
4-Station Automatic Tool Turret for 3/4" (20 mm) turning tools
  • Industry-standard bolt pattern
  • Black oxide coating for corrosion resistance
  • Haas-designed OEM tooling
8-STATION TOOL TURRET
8-Station Automatic Tool Turret; gang-style tooling with 1/2" (12.7 mm) centers
  • Compatible with industry-standard gang-style tooling with 1/2" centers
  • Widely available aftermarket tooling
  • Allows greater flexibility and tooling standardization
VIDEOS
