      • Fiber Laser
      • VF-4SS
EXTERNAL (OD) TURNING TOOLS
HAAS TESTED. HAAS PROVEN.
SEE ALL OD TOOLHOLDERS
  2. Lathe Tooling
  3. External (OD) Turning Tools
EXTERNAL (OD) TURNING TOOLS OVERVIEW
These high-quality indexable turning tools for external profiling and facing are constructed of hardened tool steel, and feature a precision pocket and secure clamping mechanism for the indexable inserts. They are available in shank sizes from 0.500" to 1.25", in a variety of tool lengths. Choose the insert shape, clamp style, and tool orientation to fit your specific application.
BLOCK SHANK HEIGHT FOR HAAS TURNING CENTERS
Inch Turrets
Metric Turrets
Clamping Styles
D – Double-Clamp System
• For negative-style inserts
• Powerful single-lever screw clamping
• Spring design releases clamp automatically
• Optimized for chip flow
M – Multi-Lock System*
• Eccentric lock pin secures the insert against the side
• Top clamp provides rigid downward clamping
S – Screw-On System
• For positive-style inserts
* For multi-lock holders: Rotate the eccentric lock pin counterclockwise until the insert drops on, and then rotate the eccentric pin clockwise to secure the insert against the side of the holder. Install the top clamp to hold down the insert.
INSERT STYLES
Insert Styles
C-Style Inserts – Diamond 80°
For external machining and facing. The large point angle is very rigid, and good for rough machining. This is the most commonly used insert.
D-Style Inserts – Diamond 55°
The smaller point angle of this insert is more versatile for finishing and detail work, but it has less cutting-edge strength than other geometries.
V-Style Inserts – Diamond 35°
W-Style Inserts – Trigon 80°
This insert has 3 cutting edges per side. The 80° cutting angle provides high cutting-edge strength for roughing, but the depth of cut is limited by the short cutting edge.
LARGE NOSE ANGLE
SMALL NOSE ANGLE
LARGE NOSE ANGLE
• Stronger cutting edge
• Higher cutting forces
• More vibration
• Higher feedrates
SMALL NOSE ANGLE
• Better access to features
• Lower cutting forces
• Weaker cutting edge
• Lower vibrations
