      • Fiber Laser
      • VF-4SS
INTERNAL (ID) GROOVING & THREADING TOOLS
HAAS TESTED. HAAS PROVEN.
SEE ALL SMALL ID GROOVING AND THREADING TOOLS
VISE PARALLELS
  2. Lathe Tooling
  3. Internal (ID) Grooving & Threading Tools
HAAS SMALL ID GROOVING AND THREADING TOOLS
Small ID Grooving and Threading Tools
Haas multi-functional fine tools can be used for high-accuracy, small-diameter machining of internal grooves, profiles, and threads, as well as for facing and general turning operations. These low-vibration carbide toolholders accept a large selection of inserts for different applications, such as chamfering, threading, and backboring.
Advantages
  • Strong clamping system and specially designed inserts are suitable for small-diameter machining
  • Six kinds of inserts can be clamped in one holder for various operations
  • Guaranteed long tool life, due to a tough substrate with TiAIN coating
  • High-accuracy ground inserts ensure high-precision machining
Application range
  • Internal grooving, profiling, threading, and boring operations at minimum diameters of: 5/16" – 5/8"  (7.94 – 15.88mm).
