      • Fiber Laser
      • VF-4SS
5C COLLET KITS
HAAS TESTED. HAAS PROVEN.
SEE ALL 5C COLLETS KITS
  2. Lathe Workholding
  3. 5C Collet Sets
5C COLLETS OVERVIEW
5C collets, also known as 385E collets, are a popular alternative to standard 3-jaw chucks for holding cylindrical workpieces up to 1-1/8” or 28mm, and bar stock up to 1” or 25mm in diameter. Collets are easy to change out, allowing faster set-up times, and they provide 360-degree support for the workpiece for higher accuracy. These collets provide a much stronger grip and superior concentricity than a standard 3-jaw chuck.
Collet Selection Guidelines:
  • Collets are available individually or in kits
  • Collet series is determined by the internal surface and shape (smooth or serrated round, square, hexagonal, etc.)
  • Collet bore diameter is determined by the workpiece diameter
Round 5C Collets:
  • Can be used to hold any type of round or odd-shaped material
  • Strong grip of material for a variety of machining applications
  • Provide 360-degree support for the workpiece
  • High accuracy and concentricity
  • Repeatable and easy to use
5C Round Collet Clamping Range (Inch):
  • 1/16" to 1-1/8" in 1/64" increments
5C Round Collet Clamping Range (Metric):
  • 3mm to 28mm in 0.5mm increments
