      • Fiber Laser
      • VF-4SS
TEST BARS
HAAS TESTED. HAAS PROVEN.
SEE ALL TEST BARS
  2. Machine Maintenance
  3. Spindle Test Bars
Spindle Test Bar Details
Spindle test bars are a quick and easy way to verify the runout and alignment of your machine’s spindle after a crash, after the machine has been moved, or as a periodic performance check. Excessive runout and axial play in a machine tool spindle are the major causes of excessive tool wear and tool breakage. Use one of our high-precision spindle test bars to verify that your spindle is running accurately, to ensure consistent parts and a stable production environment.
FEATURES AND BENEFITS:
  • Identifies potential problems with spindles and bearings
  • Helps reduce machine downtime and costly repairs
  • Includes a sturdy aluminum case to protect and store test bar
SPECIFICATIONS:
  • Runout accuracy: 0.003 mm
  • Surface roughness: Ra 0.1 μm
  • Outer diameter tolerance: ±0.005 μm
Spindle test bars are for static use only. Do not operate the spindle with the test bar installed.
