      • Fiber Laser
      • VF-4SS
3-JAW CHUCKS & MOUNTS FOR MILLS
HAAS TESTED. HAAS PROVEN.
HAAS TOOLING 3-JAW CHUCK KITS FOR MILLS
Haas Tooling delivers yet another way for you to clamp your workpiece onto your vertical mill.  Our 3-Jaw Chuck Kits for Mills offer everything you need to add an 8" 3-jaw chuck to the table your machine. These kits feature either a flat, 90°, or both mounts, which are all compatible with any standard t-slot table. The included 8" manual 3-jaw chuck has reversible jaws for more workpiece clamping flexibility.  Plus, each kit contains the correct mounting hardware, making it a complete workholding solution right out of the box!
  • Mounts directly to your mill table with included hardware
  • 90° and flat table adapter plate available
  • Manual 8" chuck
  • Complete workholding solution right out of the box
90° Mill Table Adapter Plate Kit
  • All mounting hardware included
  • 90° table adapter plate
  • Manual 8" chuck
  • Reversible hard jaws for workholding flexibility
Flat Mill Table Adapter Plate Kit
  • Flat table adapter plate
  • Manual 8" chuck
  2. Manual Chucks For Milling
  3. 3-Jaw Chucks & Mounts for Mills
