      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
Hardness Tester
Portable EDM
ER COLLET CHUCKS
HAAS TESTED. HAAS PROVEN.
SEE ALL ER COLLET CHUCKS
  2. Mill Toolholding
  3. ER Collet Chucks
ER COLLETS OVERVIEW & VIDEOS
ER Collets
  • Collets are available individually or in kits
  • Collet series is determined by the toolholder ER-taper size (11, 16, 20, 25, 32, 40)
  • Collet bore diameter is determined by the cutting tool shank diameter
ER Straight-Bore Collets – Features
NOTE: These collets have a clamping range. Use the tightest collet available for any given tool shank, to provide the greatest tool-to-collet contact area while minimizing runout.
In the case of a Ø12.2 mm tool, do not use a Ø12–11 mm collet. Instead, use a Ø12.5–11.5 mm collet. For general cutting applications, a Ø13–12 mm collet is usable.
  • Can be used to hold any type of round shank tool
  • Flexibility to clamp a wide range of tool shanks
  • High accuracy and concentricity
Clamping Range:
ER8:     0.5 – 5mm
             0.012 – 0.187"
ER11:   0.5 – 8mm
             0.043 – 0.281"
ER16:   0.5 – 10mm
             0.043 – 0.375”
ER20:   0.5 – 12mm
             0.043 – 0.5”
ER25:   1 – 16mm
             0.086 – 0.625”
ER32:   2 – 20mm
             0.086 – 0.781”
ER40:   2 – 26mm
             0.086 – 1”
ER Sealed Collets – Features
NOTE: Collet bore is the exact diameter of the tool shank. These collets have no clamping range.
  • Fits all Haas ER collet chuck holders
  • Ensures 100% of through-tool/spindle coolant gets to the tip of the cutting tool
  • Approved for high-pressure coolant to 1100 psi
  • Short rear collet slots provide a mechanical seal, blocking coolant flow
  • Mechanical seal design is superior to silicone/rubber sealed collets
  • Do not require a coolant ring or special ER nut
  • To seal properly, the entire tool shank must be in the collet and cover all slots
ER Tap Collets – Features
  • Collet bore is the exact tool diameter, with a square drive
  • Special design locks flat-sided tap shanks into the collet
  • Provides maximum concentricity, with positive driving force
  • Reduces tapping clearance requirements
Toolholder and Pull Stud specifications
Toolholder Maintenance
ER COLLETS RUNOUT TOLERANCE
DIN ISO 15488 specifies the dimensions, materials and manufacturing requirements, and designation of collets (of form A or of form B) for tools with cylindrical shanks and their corresponding holders and nuts. All Haas ER collets are manufactured to meet or exceed these requirements.
    Form A: 6 to 8 slots.
    Form B: 12 to 16 slots.
This International Standard also specifies collet runout tolerances. These tolerances are checked as is shown in the figure below, by the introduction of a test mandrel into the collet. The diameter of the test mandrel is the nominal diameter of the collet.
For the test mandrel, the following specifications apply:
    a) diameter tolerance: h6;
    b) cylindricity: 0.002mm;
    c) parallelism: 0.002mm;
    d) roundness: 0.002mm;
    e) surface without longitudinal marks;
    f) maximum surface roughness Rz = 4µm;
    g) surface hardness: (58 +3/-0) HRC.
Dimensions in millimeters
d
H7
Nominal Diameter
L
Runout Tolerance (a)
Above
Up To (Included)
Class 1 (b)
Class 2
1 (Included)
1.6
0.01
0.015
1.6
16
25
18
40
0.015
0.020
18
26
50
 a     Normal style collets are designed with runout tolerance class 2. If class 1 is required, it shall be given separately.
 b     In the case of applications where runout tolerances class 1 are required, the accuracy of the whole system (machine tool spindle, holder, collet, and tool) shall be observed.
ER COLLET CHUCKS OVERVIEW
ER Collet Chucks – Features
  • Powerful chucking, high precision, and easy operation
  • Stable, precise machining at high rotational speeds
  • Small-bore nut design minimizes interference with workpiece, and speeds operation
  • Various nuts can be used, depending on application
  • Double-taper collets have longer clamping area for excellent gripping torque
Hollow Taper Shank (HSK) Toolholding – Benefits
  • Dual-contact taper for high rigidity and high accuracy
  • More rigid toolholders for long-reach tools
  • Increased performance for 3D profiling
  • Increased performance when using small cutting tools
STRONG GRIPPING TORQUE
  • The longer clamping area of the double-taper collet provides stronger gripping force, and higher transferrable torque
  • Additional gripping torque can be achieved by using a ball bearing nut
STANDARD ER COLLET TORQUE SPECIFICATIONS
Proper torque is an important variable for toolholding; too little torque and the cutting tool can slip, pull-out, or vibrate excessively, and too much torque can lead to accelerated wear, damage, or potentially increased runout (TIR). Below is a table that suggests standard torque values for each respective ER-taper size.
EASY ASSEMBLY AND DISASSEMBLY
To assemble the collet, gently insert the groove of the collet into the eccentric ring inside the nut, and then snap the collet into place. To disassemble the collet, tilt the collet to the side until it snaps out of the eccentric ring, and remove it from the nut.
Enhance your machining capabilities with our high-quality ER collet chucks. Discover a range of chucks designed for precision toolholding and superior performance. Our ER collet chucks offer excellent rigidity, runout accuracy, and clamping force, ensuring optimal results in milling and other machining operations. Choose from various sizes and configurations to meet your specific needs.
