      • Fiber Laser
      • VF-4SS
PULL STUDS
HAAS TESTED. HAAS PROVEN.
SEE ALL PULL STUDS
  2. Mill Toolholding
  3. Pull Studs / Retention Knobs
TSC VS. SOLID PULL STUDS
Pull Studs
TSC Pull Studs:
TSC (through-spindle coolant) pull studs have a hole through the center that allows through-spindle coolant to flow through the toolholder.
Solid Pull Studs:
Solid pull studs do not have a hole through the center, and WILL NOT allow through-spindle coolant to flow through the toolholder.
Toolholder and Pull Stud specifications
How Our Pull Studs Are Made
Step One:
  • Starts out as 8640 alloy steel (DIN 40NiCrMo2-2)
  • Rough out the general profile on a lathe
Step Two:
  • To increase the longevity of our pull studs, each pull stud is heat treated to a minimum of HRC60
Step Three:
  • Pull studs are put back on a lathe for finish profiling and threading
The Final Product:
  • Lastly, pull studs are inspected, packed, and ready for shipment!
Enhance the performance of your machining operations with high-quality pull studs/retention knobs. Explore a range of precision-engineered studs and knobs designed for secure and efficient toolholding.
