      • Fiber Laser
      • VF-4SS
Angle Plates Details
Angle Plates are robust, 90-degree sections of accurately machined material, typically made of cast iron or steel. They offer exceptional flatness and perpendicularity for quick inspections, and can be used to accurately secure and clamp materials that require more complex workholding solutions.
Plate Type
Solid
Featureless plate. Preferable for unique workholding setups that require custom sizing or spacing.
Slotted
Equipped with predefined slots for easy fixturing and set up.
Plate Style
Gusset Angle Plates offer higher strength and rigidity due to the connecting web, or gusset, that joins the opposing plates. The gusset allows greater force to be applied on a surface without compromising perpendicularity.
Webbed Gusset
Two small webbed gussets provide higher strength and rigidity. Advantageous when clearance is critical for more complex fastening.
Right-Angle Handle Gusset
Have a large, 90-degree gusset with two additional sides finished square and parallel. Provides higher strength and rigidity, and is an ideal reference for quick squaring operations. Also known as a right-angle iron.
Open-Ended
Offer ample surface area for an easier application of bolts, nuts, clamps, and other fixturing mechanisms.
  2. Mill Workholding
  3. Angle Plates
