      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
Hardness Tester
Portable EDM
TOOL PRESETTING MACHINES
HAAS TESTED. HAAS PROVEN.
SEE ALL TOOL PRESETTING MACHINES
FREE SELECT TOOLHOLDERS & PULL STUDS!
BUY THE HAAS TOOL PRESETTER
GET 10 FREE SELECT TOOLHOLDERS + FREE PULL STUDS!
Learn more
SAVE MORE WHEN YOU BUY BOTH!
UP TO $1000 SAVINGS + 20 FREE SELECT TOOLHOLDERS
Learn more
* Discount will be shown in your cart, once all items are added. Excludes: Milling Chucks, Drill Chucks, and Hydraulic Milling Chucks
  2. Tool Presetter & Heat Shrinkers
  3. Tool Presetting Machines
HAAS TOOL PRESETTERS
Haas Tool Presetter Series:
ORDER NOW - FREE SHIPPING!
Haas Tool Presetters, designed to streamline your workflow, are the ultimate solution for maximizing efficiency and maintaining precision in your machining operations. By eliminating the need for manual tool measuring, presetters allow tool offsets to be taken prior to each job, ultimately maximizing spindle time and leading to more efficient production runs.
Equipped with pre-installed training videos and step-by-step online guides, measuring and inspecting complex tool geometries becomes a breeze. At no extra cost, each presetter offers three versatile data transfer methods such as, LAN connection, USB, and data matrix scanner to transfer tool offset values, minimizing human error when inputting data. The built-in post processors support Haas Classic and Next Generation Controls (NGC), as well as numerous other machine control options.
Three presetter options are available, each tailored to meet specific customer needs. The range of X & Z axis travels, interchangeable taper sleeves to support numerous machines, and pneumatic capabilities for enhanced precision on the intermediate and advanced models, make these the most cost-effective and versatile solutions on the market.
BENEFITS:
  • Fully equipped and easy-to-use tool presetter – plug-n-play with all Haas machines
  • How-to videos on the unit for ease of use
  • Transfer generated tool data to your Haas machine over local area network, using a USB memory device, or via a printed label scanned by the Haas Industrial Wireless Data Matrix Scanner
  • Supports ISO30, ISO40, ISO50 and HSK63A tools via high-precision interchangeable tool sleeves
  • Simple and intuitive multi-language software
LEARN MORE
INSTALLATION
____________________________________
Your new Haas Tool Presetter will be delivered directly to your shop (or designated address) in a secure shipping crate, and will require basic assembly and set up. A step-by-step installation guide is included – and available here – so you can install and set up the unit yourself. Our easy-to-follow, step-by-step guide walks you through the entire process, so you’ll be up and running quickly; and installing the unit yourself does not void your warranty.
You may also have the unit installed by your local Haas Factory Outlet. Installation is free; however, travel charges will apply. Simply contact your local HFO to schedule the installation.
HTS400
  • Maximum X-Axis Travel: 12.598” (320 mm)
  • Maximum Z-Axis Travel: 15.748” (400 mm)
  • 5000 Tool Memory
  • 50 Machine Origin Memory
  • Standard 40 Taper Tool Sleeve
  • 20” Monitor
  • Table-top Unit
HTS600
  • Maximum X-Axis Travel: 15.748” (400 mm)
  • Maximum Z-Axis Travel: 23.622” (600 mm)
  • 10,000 Tool Memory
  • 100 Machine Origin
  • Pneumatic Axis Clamping
  • Pneumatic Tool Interlocking System
  • 22” Monitor
  • Table-top Unit
HPTS600
  • 20,000 Tool Memory
  • 200 Machine Origins
  • Pneumatic Taper Sleeve Brake
  • Standard 50 Taper Tool Sleeve
  • 24” Monitor
  • Stand-alone Unit
ADDING A TOOL PRESETTER TO YOUR CNC
THE OLD WAY
  • Find a tool pre-setter that you think can work for your needs.
  • Hope that training and service are available in your area.
  • Struggle through set up and integration into your shop’s processes.
  • Never quite get the “ease of use” promised for getting the tool setting information into the machine.
THE HAAS WAY
  • Go to HaasTooling.com
  • Select the Haas HTS400 (online financing available!), and use a single bar code scan to input all tooling data into the Haas control.
  • Delivery right to your door, with an extensive library of videos and documentation built-in, and all the necessary information and support available at HaasTooling.com.
HAAS MAKES
TOOL PRESETTING EASY
