      • Fiber Laser
      • VF-4SS
      • 00-0012
SPINDLE TAPER CLEANER
HAAS TESTED. HAAS PROVEN.
SEE ALL SPINDLE TAPER CLEANER
  2. Tooling Accessories
  3. Spindle & Toolholder Taper Cleaners
SPINDLE TAPER CLEANERS OVERVIEW
Spindle Taper Cleaners Overview
A clean spindle taper is essential for maintaining proper contact between the toolholder and the spindle taper. Any buildup of dust, chips, lubricant, or other contaminants in the spindle taper can cause premature wear, increase tool runout, shorten tool life, and reduce part accuracy.
Electric toolholder taper cleaners provide a simple and effective way to clean rotary toolholders. Equipped with three large orbital brushes, these machines are designed to quickly remove machining debris and carbon buildup on rotary toolholders, without scratching or marring the surfaces that interface with your machine's spindle. The 40-taper and 50-taper electric brush head includes the necessary adapter rings to fit their corresponding BT, CT, and SK40/50 machines.
How to use:
  1. Put rust preventative on tool
  2. Put tool into holder (using the proper adapter ring and taper head)
  3. Adjust the knob for your desired cleaning length
  4. Push the knob to start
These easy-to-use spindle taper cleaners are constructed of rigid plastic, with soft fiber pads that quickly remove debris and contaminants, without damaging the taper. Regular use can help maintain the overall precision of the machine, and prolong the life of your spindle, toolholders, and cutting tools.
