      • Fiber Laser
      • VF-4SS
TOOLHOLDER FIXTURES
HAAS TESTED. HAAS PROVEN.
SEE ALL TOOLHOLDER FIXTURES
  2. Tooling Accessories
  3. Toolholder Fixtures
TOOLHOLDER FIXTURES OVERVIEW
Haas Toolholder Fixtures
Haas toolholder fixtures provide a safe, easy, and secure way to ensure that your pull studs and cutting tools are securely tightened into your toolholders.
Each tightening fixture features a lightweight cast-iron body that is very rigid, and easily bolts to the edge of a worktable or tool cart, allowing the user to change tools quickly and safely. The compact design holds toolholders in the vertical position for changing out cutting tools and inserts, and in the horizontal positions to allow easy access to the pull-stud or side screw.
Simply place the toolholder between the steel keys in the fixture to prevent the holder from rotating as you tighten and loosen collet nuts, set screws, or pull studs. These units not only provide strong gripping power, but also protect the toolholders from the type of damage often caused by improper gripping methods.
FEATURES:
  • Lightweight cast-iron body
  • Compact design mounts easily to a worktable or tool cart
  • Cast aluminum vertical taper and horizontal holders
  • Long-wearing steel inserts to engage the toolholder drive slots
BENEFITS:
  • Holds the toolholder securely for maximum protection
  • Strong gripping power in both horizontal and vertical positions
  • Provides easy access to the cutting tool and pull stud
  • Available in all common machine tapers
