    2. Español - España
    3. Español - México
    6. Český
    7. Nederlands
    8. Magyar
    9. Polski
    10. Svenska
    11. 中文
    12. Suomi
    13. Norsk
    14. الإنجليزية
    15. български
    16. Hrvatski
    17. Ελληνικά
    18. Slovenský
    19. Slovenščina
    20. 한국어
    21. 日本語
      • Smerigliatrice di superficie
    2. Español - España
    3. Español - México
    6. Český
    7. Nederlands
    8. Magyar
    9. Polski
    10. Svenska
    11. 中文
    12. Suomi
    13. Norsk
    14. الإنجليزية
    15. български
    16. Hrvatski
    17. Ελληνικά
    18. Slovenský
    19. Slovenščina
    20. 한국어
    21. 日本語
Rotary Control Battery Replacement
Pagina iniziale Assistenza Procedure d’uso Rotary Control Battery Replacement
6.5 Servo Control - Battery Replacement
This procedure will show you how to replace the batteries on a Servo Control Box.
Warning: The Rotary Servo Control box will not work properly without the batteries.  These batteries are used by the control to retain the rotary servo control configuration parameters and programs.
Parts Required:
  • Lithium Battery (Qty: 2) (see note for sourcing instructions)
NOTE: To determine which battery to source please refer to our Lithium Battery Reference Guide
Battery Installation
Remove the SHCS using a 7/64 allen key that hold the cover of the rotary box.
Note: Be careful with the rotary box fan cable and external battery cable.
Remove the clips on the external battery board [1].
Install the batteries and place the clips back around the batteries as they were found originally.
  • The external battery board is mounted on the side of the cover using Velcro and can be removed from the Velcro to make installing the batteries easier.
  • Reinstall the cover and verify the rotary control box functions properly
Refer to the How to Initialize Servo Control to Factory Default Parameters procedure.
IR11-12UN Inserto per filettatura, Grado HU35T - Confezione da 10 $146.95 $132.97
