ABB Wye/Delta - N.O. AUX Contacts - Installation - AD0571
Service Home How To Procedures ABB Wye/Delta - N.O. AUX Contacts - Installation - AD0571
Recently Updated Last updated: 09/24/2021
AD0571
This procedure outlines how to install ABB Normally Open (N.O.) AUX contacts to the ABB Wye/Delta assembly.
This procedure applies to the following service kits:
  • 93-3418: ABB Y/D N.O. CONTACTS SERVICE KIT
Move the N.C. AUX contacts to the center position of each contactor (see red boxed contacts in image). To remove the N.C. AUX contacts press up the latch [1] and slide the N.C. AUX contacts forward.
Remove the red [2] and red/white [3] wires on cable 33-1071 from the internal N.O. contact in the Delta contactor.
Note: For assembly 32-5282C, the red [2] and red/white [3] wires are from cable 33-1068.
Remove the black [4] and black/white [5] wires from the internal N.O. contact in the Wye contactor.
Install the N.O. AUX contacts from the kit onto the right most position of each contactor (see red boxed contacts in image).
Connect the red [1] and red/white [2] wires from cable 33-1071 to the N.O. AUX contact as shown.
Connect the black [3] and black/white [4] wires to the N.O. AUX contact as shown.
Note: Torque the N.O. AUX contact screws to 1 Nm.
Verification
 Handle jog the spindle back and forth until the WYE and DELTA contactors change states.
Warning: If you have a lathe, make sure to remove any parts from the workholding before jogging the spindle.
If alarms are generated, check the connections.
