Machine Data Backup (Mill 15.xx and lower and Lathe 8.xx and lower) - CHC
Service Home How To Procedures Machine Data Backup (Mill 15.xx and lower and Lathe 8.xx and lower) - CHC
Recently Updated Last updated: 09/19/2018
Machine Data Backup (Mill 15.xx and lower, and Lathe 8.xx and lower) - CHC
Applies to machines built from: January, 1989 to July, 2013
- Jump to Section - 1. Introduction 2. Machine Data Backup (2 steps) Back to Top
This procedure will backup all of the machine data files on your machine.
For machines with Mill 16.xx and higher or Lathe 9.xx and higher, use Machine Data Backup (Mill16.xx and higher, and Lathe 9.xx and higher).
To backup only the program files, use Classic Haas Control - Backup Programs procedure.
For this procedure, a USB or floppy drive on the side of the control pendant or in the electrical cabinet  is required
Tools required:
  • USB memory device
  • Floppy Disk
Machine Data Backup
To find the software version of your machine, push [PARAMETER] (2) times. Push [PAGE DOWN] until you find the INPUTS 2 display. The software version is shown at the bottom.
Make sure your floppy disk or USB memory device is inserted into the pendant or the back of the control cabinet.
Change setting 7 and 23 to OFF. For mills with the side-mount tool changer option, change setting 155 to ON.
Push [LIST PROGRAM]. Go to the device where you want to back up your files.
Push [POSITION] [1]. Type the serial number of the machine.
Push [F2]. Wait until the pendant reads DISK DONE [2].
Push [LIST PROGRAM]. Go to the device where you backed up the files. Verify that they are on the device.
If your machine loses its data,  use these steps to put the data back onto the machine:
  1. Call your Haas Factory Outlet to enable your machine options.
  2. Push [EMERGENCY STOP].
  3. Push [SETTING]. Change setting 7 to OFF.
  4. Insert your memory device.
  5. Push [LIST PROGRAM]. If the machine has DEVICE display, push the UP or DOWN CURSOR arrows to select the memory device. If the machine does not have DEVICE display, the files from MEMORY will show.
  6. Push [PARAMETER].
  7. Type the name of the backup parameter file you want to restore. Push [F3]. Wait until the pendant reads DISK DONE.
  8. Repeat this process for SETTINGS. If you have macro files you want to restore, push [CURRENT COMMANDS]. Push [PAGE UP] to go to the MACRO VARIABLES display. Repeat step 5.
  9. Push [POWER OFF].
  10. Push [POWER ON].
