DC AutoDoor Motor - Replacement - AD0469
Service Home How To Procedures DC AutoDoor Motor - Replacement - AD0469
Recently Updated Last updated: 02/02/2021
AD0469
This procedure will show you how to replace the DC AutoDoor Motor on a VMC or Lathe CNC.
Machine Requirements:
  • Software Version 100.20.000.1200 or higher
  • I/O PCB 34-3490B or higher
  • AD PCB 34-3096, 34-3096A with Firmware Version 1.42 or higher
  • I/O Firmware version 4.09 or higher
  • TC Firmware version 2.06 or higher
  • 93-3414: AUTO DOOR MOTOR 55RPM
Replacement
Power OFF the machine.
Remove the autodoor motor cover.
Disconnect the airlines and power cable from the motor assembly.
Remove the autodoor motor assembly.
Remove the nut [1], lock washer [2].
Pull the pulley out of the motor shaft.
Remove the three socket head cap screws [4].
Remove the old motor [5] and install the new one.
 Note:  For machines built before 09/16/2019 add retaining clips to the belt refer to DC Autodoor Track Replacement procedure.
Update the configuration files to make sure you have the latest autodoor values.  Refer to Configuration File - Download/Load - NGC procedure.
