Spindle and Spindle Motor - Tooth Pulley and Cog Belt - Grease - Application
Service Home How To Procedures Spindle and Spindle Motor - Tooth Pulley and Cog Belt - Grease - Application
Recently Updated Last updated: 08/08/2023
Applies to machines built from: January, 1989
- Jump to Section - 1. Grease Application (1 step) Back to Top
Grease Application
This procedure tells you how to apply grease to the spindle and motor pulleys and to the spindle belts. Do this after you install a new belt and adjust the belt tension. This reduces spindle noise.
Lightly apply PN 99-4521A GREASE, SILICONE – 5.3 OZ [A] to (5) teeth on the motor pulley [1].
Manually turn the spindle [1] until each pulley and belt has a thin layer of grease. Remove all excess grease.
A10H-SCLCR0306, 10mm Ø Steel Shank Internal (ID) Boring Bar, Right-Hand, Screw-Lock, Through-Tool Coolant $48.95 $41.97
