      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
Counterbalance Pressure Switches
Service Home Service Updates Counterbalance Pressure Switches
We have received back multiple complete counterbalance kits due to faulty pressure switches. You do not need to replace the complete system if one component has failed. If the pressure switch fails you can follow the VMC - Hydraulic Counterbalance - Pressure Switch - Replacement, AD0331, to replace the switch.
It is recommended to replace the tank and cylinder together if the cylinder has failed but other components such as the gauge and pressure switch do not need a complete system change.
