  1. Haas Service Parts
  2. Maintenance
  3. Grease, Oil, & Sealants
  4. 93-99-4452
SILICONE, RTV ASI 335 - 10.2 FL OZ / 301 ML
Part #: 93-99-4452
SILICONE RTV ASI 335 - 10.2 FL OZ-301 ML
Price: 14.95 ( / unit)
ASI 335 Neutral Cure Silicone Sealant/Adhesive is a one-part, non-slump, moisture-curing RTV (room temperature vulcanizing) that cures to form a tough, high modulus rubber with long-term flexibility and durability.
The neutral curing mechanism of ASI 335 is ideally suited for use in confined work areas since no objectionable odors are evolved. The non-slump characteristics of ASI 335 allow application to vertical or horizontal joints without flowing or sagging.
ASI 335 has excellent resistance to weathering including ozone, ultraviolet radiation, freeze-thaw conditions and airborne chemicals. After cure, the wide heat stability range of ASI 335 is from -57°C to +204°C (-70°F to +400°F) and the sealant can be applied to surface temperatures from -18°C to +50°C (0°F to +120°F).
Note: Part # 93-99-4452 replaces Part # 99-4452
  • Procedure Guide
  • Safety Data Sheet
93-99-4452
