Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • 5% off + saving on Automation
      • VF-2SS
    • 08-1760
      08-1760
      08-1760 View All
      • 08-1760
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Management Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Storage & Handling Measuring & Inspection
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
    • Manual Chucks
      Manual Chucks Shop All
    • Milling
      Milling Shop All
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove and Thread Inserts
      • Haas Notch Groove and Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
    • Tool Management
      Tool Management Shop All
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
    • Storage & Handling
      Storage & Handling Shop All
      • 7-Piece Measuring Kit
      • WIPS Stylus, 3-Pack
      • WIPS Replacement Stylus
      • Spindle Test Bar
      • Coolant Refractometer
      • Clamp Force Gauge
      NEW PRODUCTS NEW PRODUCTS
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
Search
Drill Chucks
Pull Studs
Fixed Jaw Vises
Mill Vise Jaws
Manual Chucks
Milling
Burrs
Cut-Off Tooling
Grooving Tools
Boring Bars
OD Toolholders
TL & CL Toolholding
BOT Toolholding
BMT Toolholding
Live Toolholding
Reduction Sleeves
VDI Toolholding
Spindle Liners
Lathe Collet Chucks
Lathe Boring Rings
ER Collets
Tool Management
CNC Clearing Fans
Lathe Tooling Kits
Storage & Handling
WIPS Stylus, 3-Pack
Spindle Test Bar
Clamp Force Gauge
CAN’T FIND YOUR PART?
CAN’T FIND WHAT YOU’RE LOOKING FOR? CHECK OUT HAASPARTS.COM!
LEARN MORE
Not all service items are available for direct purchase online. However, they may be available at HaasParts.com for purchase through your local HFO.
Some service items require special tools, have specific installation procedures, or must be installed by an authorized Haas service engineer. We want to make sure you get the right parts for your machine, and that they are installed correctly, so you can keep making chips.
Visit HaasParts.com
  1. Haas Service Parts
  2. Maintenance
  3. Grease, Oil, & Sealants
  4. 93-99-4465
Never Run Out of the Tools and Inserts You Need – Subscribe Today
Never experience the frustration of starting a job and finding out that you do not have all the right tools. Use our new subscription feature to automatically reorder the tools and inserts you use most often, on a schedule of your choosing – so you are always ready to run.
To set up your order as a weekly or monthly subscription, proceed through the checkout process, and select Schedule Subscription before selecting Place Order. All items in your cart must be eligible for subscription, in order to schedule a reorder.
SEALANT, RTV 108 - 2.8 FL OZ
Part #: 93-99-4465
Price: 24.95
Each pack contains s not sold individually.
Price: 22.79
RTV Silicone Sealant, High Performance, Acetoxy Cure, 10.1 oz., Clear, Temp. Range -75 to 400 Degrees F, Specific Gravity 1.05, Flash Point 200 Degrees F, Full Cure 24 hr., Application Time 10 min., Substrates Most Metals Including Steel and Aluminum, Easy to Apply, Sets Up Quickly, Includes Nozzle.
Product Features:
  • One-component products
  • Capability to cure at room temperature and ambient humidity
  • Self-adhesion properties
  • Low-temperature flexibility
  • High-temperature performance
  • Excellent weather ability and ozone and chemical resistance
  • Excellent electrical insulation properties
Note: Part # 93-99-4465 replaces Part # 99-4465
  • Procedure Guide
  • Safety Data Sheet
93-99-4465
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
