THREADING INSERTS
HAAS TESTED. HAAS PROVEN.
SEE ALL THREADING INSERTS
  2. Lathe Tooling
  3. Threading Inserts
THREADING INSERTS OVERVIEW
Haas threading inserts are available for machining various shapes of internal or external threads at various pitches, while ensuring high-quality performance. These laydown thread inserts have 3 cutting edges, and options for different forms of chip breaker, for a range of different IC sizes. Grades are available to machine all ranges of steel, stainless steel, and cast-iron.
Partial-profile inserts cut without topping the outer diameter of the thread, allowing the same insert to be used for a range of thread pitches that have a common thread angle.
Full-profile inserts, also known as topping inserts, will form a complete thread, including the crest. For every thread pitch and standard, a separate insert is required.
NOTE: Insert orientation must match tool orientation for the correct fit. Refer to the insert technical details on the product pages for more information.
THREAD INSERT CODE SYSTEM (ISO)
Videos
