      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
Hardness Tester
Portable EDM
SPINDLE LINERS
HAAS TESTED. HAAS PROVEN.
SEE ALL SPINDLE LINERS
  2. Lathe Workholding
HAAS EXTRUDED SPINDLE LINERS
Haas Extruded Spindle Liners
Haas extruded spindle liners are an inexpensive, easily installed option that provides extra stability to bar stock during turning operations, producing better results and allowing higher spindle speeds. The decreased vibration will result in better part finishes and accuracy. When combined with the Haas liner guide adapter kit, liner changeovers are a snap – up to ten times faster than other versions – so you can be up and running in no time.
  • Durable, extruded high-density polyethylene for long life
  • Patented fin-shaped design for concentric fit to minimize vibrations
  • Clearly labeled for quick identification
  • Low-cost solution
How To Mount The Liner Adapter To The Haas Lathe
Spindle Liner And Adapter Assembly Options
SPINDLE ADAPTER & LINERS COMPATIBILITY
Liner Adapter Compatibility
Corresponding Liners (Apply to machines built from 2005)
Lathe Model Adapter Kit Compatability Applies to Machines Built from… Adapter Kit
 Liner Kit Liner Kit Items Liner Part Number Fits Bar Diameter (Inch) Fits Bar Diamter (mm)
ST-10, ST-10Y March 2017 to Present Liner Adapter 1.75 Haas Part Number
05-0207
LINER KIT 1.75
08-0281
Universal
LINER375 05-0188 0.375 10
LINER500 05-0187 0.5 13
LINER625 05-0186 0.625 16
LINER750 05-0185 0.75 19
LINER875 05-0184 0.875 22
LINER1000 05-0203 1 25
LINER1125 05-0202 1.125 29
LINER1250 05-0201 1.25 32
LINER1375 05-0200 1.375 35
LINER1500 05-0199 1.5 38
LINER1625 05-0198 1.625 41
LINER KIT 1.8
08-2011
Inch
LINER 3/8 X 1.8 x 48" 05-0617 0.375 -
LINER 1/2 X 1.8 X 48" 05-0616 0.5 -
LINER 5/8 X 1.8 X 48" 05-0615 0.625 -
LINER 7/8 X 1.8 X 48" 05-0614 0.875 -
LINER 3/4 X 1.8 X 48" 05-0613 0.75 -
LINER 1 X 1.8 X 48" 05-0612 1 -
LINER 1-1/8 X 1.8 X 48" 05-0611 1.125 -
LINER 1-1/4 X 1.8 X 48" 05-0610 1.25 -
LINER 1-3/8 X 1.8 X 48" 05-0609 1.375 -
LINER 1-1/2 X 1.8 X 48" 05-0608 1.5 -
LINER 1-5/8 X 1.8 X 48" 05-0607 1.625 -
LINER KIT 46 M
08-2012
Metric
LINER 10 X 46 X 1220 MM 05-0637 - 10
LINER 12 X 46 X 1220 MM 05-0636 - 12
LINER 16 X 46 X 1220 MM 05-0635 - 16
LINER 18 X 46 X 1220 MM 05-0634 - 18
LINER 20 X 46 X 1220 MM 05-0633 - 20
LINER 25 X 46 X 1220 MM 05-0632 - 25
LINER 30 X 46 X 1220 MM 05-0631 - 30
LINER 32 X 46 X 1220 MM 05-0630 - 32
LINER 35 X 46 X 1220 MM 05-0629 - 35
LINER 38 X 46 X 1220 MM 05-0628 - 38
LINER 40 X 46 X 1220 MM 05-0627 - 40
ST-15, ST-15Y October 2019 to Present Liner Adapter 2.5 Haas Part number
05-0208
LINER KIT 2.5
08-0214
Universal
Includes LINER KIT 1.75, plus:
LINER1750-20B 05-0196 1.75 44
LINER2000-20B 05-0194 2 51
LINER2250-20B 05-0192 2.25 57
LINER KIT 2.5
08-2023
Inch
Includes LINER KIT 1.8 PRECISION, plus
LINER 2.25 X 2.5 X 48"​ 05-0604 2.25 -
LINER 2 X 2.5 X 48"​ 05-0605 2 -
LINER 1.75 X 2.5 X 48"​ 05-0606 1.75 -
ST-20, ST-20Y April 2019 to Present LINER SLEEVE 1.80 X 2.5 X 48" 05-0734 1.8 -
LINER KIT 64 M
08-2024
Metric
Includes LINER KIT 46 M PRECISION, plus
LINER 55 X 64 X 1220 MM​ 05-0624 - 55
LINER 50 X 64 X 1220 MM​ 05-0625 - 50
LINER 45 X 64 X 1220 MM​ 05-0626 - 45
LINER SLEEVE 1.80 X 2.5 X 48" 05-0734 - 46
ST-25, ST-25Y January 2018* to Present Liner Adapter 3.0 Haas Part Number
05-0206
LINER KIT 3.0
08-0199
Universal
LINER1750-30** 05-0195 1.75 44
LINER2000-30 05-0193 2 51
LINER2250-30 05-0191 2.25 57
LINER2500-30 05-0190 2.5 64
LINER2750-30 05-0189 2.75 70
(**) Must use 1-3/4" liner as a sleeve for smaller diameter liners
LINER KIT 3.0
08-2019
Inch
LINER 1.75 X 3 X 48"** 05-0603 1.75 -
ST-30, ST-30Y, ST-30SS, ST-30SSY LINER 2 X 3 X 48" 05-0602 2 -
LINER 2.25 X 3 X 48" 05-0601 2.25 -
LINER 2.5 X 3 X 48" 05-0600 2.5 -
LINER 2.75 X 3 X 48" 05-0599 2.75 -
LINER SLEEVE 1.80 X 3.0 X 48" 05-0735 1.8 -
LINER KIT 76 M
08-2020
Metric
DS-30 Series LINER 45 X 76 X 1220 MM​** 05-0623 - 75
LINER 50 X 76 X 1220 MM​ 05-0622 - 50
LINER 55 X 76 X 1220 MM​ 05-0621 - 55
LINER 60 X 76 X 1220 MM​ 05-0620 - 60
LINER 70 X 76 X 1220 MM​ 05-0619 - 70
LINER SLEEVE 1.80 X 3.0 X 48" 05-0735 - 46
(**) Must use 45mm liner as a sleeve for smaller diameter liners
System of Measurement [ØD] Bore Diameter Tolerance [ØED] External Diameter Tolerance
Universal - ANSI, ISO ±0.010 in / ±0.25 mm ±0.010 in / ±0.25 mm **For Non-standardized stock sizing**
Metric - ISO  +0.25 / -0.00 mm ±0.254 mm **Based off Cold Drawn Steel Standards**
Inch - ANSI  +0.010 / -0.000 in ±0.010 in **Based off Cold Drawn Steel Standards**
*Verify which tolerance works best with your application*
NOTE: For machines built pior to the above dates and full Liner and Liner Adapter compatability, click here.
VIDEOS
