      • Fiber Laser
      • VF-4SS
      • 00-0012
  2. Measuring & Inspection
  3. Height Gauges
Dial & Digital Height Gauge Overview
Take an in-depth look at the dial & digital Haas height gauges! In this video, Andrew walks you through the lineup of height gauges and even a quick overview of how height gauges can be used in shops to accurately measure parts and features!
Height gauges Details
High-Accuracy Height Gauges
Height gauges are precision instruments for measuring and scribing vertical distances or heights between reference points. The Haas height gauge line features a heavy-duty double-column design, offering better rigidity and accuracy than single-column types. Included is a carbide tipped scriber that can be swapped for other accessories such as indicator holders, depth gauge attachments, and center masters. Large handwheel on the slider allows for smooth and easy adjustment of heights. The base is hardened, ground, and lapped for maximum flatness.
  • Offered in dial and digital versions
  • Available in 12" (300mm), 20" (500mm), or 24" (600mm) ranges
  • Metric and inch (U.S. Only) versions available
Dial Height Gauges
  • Large, easy-to-read dial
  • Offered in inch (U.S. only) and metric versions
  • Two counters – one counting in the plus direction and the other counting in the minus direction
  • Counters can be zeroed at any position for taking comparative measurements
Range:  12" (300mm), 20" (500mm), or 24" (600mm)
Graduations:  .001 in \ 0.01mm
Accuracy: ± 0.0015 - ± 0.002 in \ ± 0.04 - ± 0.05 mm
Filter For Dial Height Gauges
Digital Height Gauges
  • Large, easy-to-read display
  • Instant switching between metric and inch measurements
  • Quickly switch between positive and negative reading directions
  • Absolute mode for taking direct measurements from a fixed zero point
  • Incremental mode for taking comparative measurements from a variable reference point
Resolution:  .0005 in \ 0.01mm
Filter For Digital Height Gauges
