  2. Tooling Accessories
  3. Cutting Tool Sharpeners
Drill Sharpeners Overview
Drill Sharpener Overview
____________________________________________________________
90˚-135˚ DRILL BIT SHARPENER MR-13B
This 90˚-135˚ Drill Bit Sharpener makes it easy to restore sharp edges to your twist drills. Whether you’re working in steel or aluminum, this sharpener ensures your bits stay in top shape. It includes a collet chuck and 11 elastic collets, designed to fit 1/8", 5/32", 3/16", 7/32", 1/4", 5/16", 11/32", 3/8", 7/16", 13/32", and 1/2" drill bits for smooth operation.
Wheel Types
Polycrystalline cubic boron nitride (CBN) grinding wheel which is ideal for high-speed steel (HSS) & cobalt (HSSCO) drills
Adjustable Angles
Different jobs call for different angles. With an adjustable point angle range from 90° to 135°, you can fine-tune your drill bits to match the material and drilling speed. The built-in positioner pins let you customize the lip relief angle and refine the web style for a sharper, more efficient point. This means less force is needed when drilling, reducing cutting resistance by up to 70%. Plus, it helps prevent material crushing at the drill’s center, making deep hole drilling easier than ever.
a) 118-Degree Angle: This angle is commonly used for drilling into aluminum, brass, and mild steels. It provides a good balance between cutting efficiency and durability, and is ideal for general-purpose drilling.
b) 135-Degree Angle: Preferred for harder steel or nickel alloys. This angle offers a more aggressive cutting action, reducing the risk of the drill bit slipping or wandering.
c) 90-Degree Angle: Known as a center drill bit, this angle is primarily used for creating starter holes or chamfers. It is commonly employed in metalworking to produce precise center holes for further drilling operations.
