  3. Collari autocentranti ER per codoli diritti
  4. 04-1485
04-1485
04-1485
04-1485
04-1485
Collare autocentrante a codolo diritto ER20 3/4" | Passaggio refrigerante nel mandrino
N. pezzo: 04-1485
ST SHANK COLLET CHUCK 3/4" X ER20
Prezzo: 69.95 ( / unità)
This straight shank ER20 collet chuck accepts a variety of ER20 collet styles, and has a 0.75 in \ 3/4" shank. The precision cylindrical shank has one flat, and will mount into any internal (ID) turning holder with the appropriate bore size and set-screw clamping. The double-taper collet design provides high clamping force for round, smooth shank tools, and offers a wide gripping range with excellent TIR and balance. The collet chuck is through-tool coolant (TSC) capable, and also may be used as an extended-length milling collet, by clamping it into the appropriate end mill holder.
Serie collare ER-20
[ØBD] Diametro del corpo 1,34 pollici
[ØDMM] Diametro codolo 0,75 pollici\3/4"
[LS] Lunghezza codolo 2,95 pollici
[LSCX] Lunghezza di serraggio massima 3,71 pollici
[OAL] Lunghezza totale 4,39 pollici
[FS] Dimensione piatta 0,71 pollici
[TP1] Filettatura M12x1,0
Peso 0,7 lb\0,3 kg
Paese d'origine Cina
04-1485
04-1485
04-1485
04-1485
04-1485
04-1485
