CM-1
  1. Vertical Mills
  2. Compact Mills
  3. CM-1
CM-1
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
Compact CNC Vertical Mill with 12" x 10" x 14" travels
Small parts manufacturing can pose significant machining challenges for the average job shop. Tiny holes, minute features, extreme accuracies, and fine surface finishes may prove difficult for larger CNC machines.
The CM-1 Compact Mill is a small-footprint, high-accuracy solution for producing and prototyping small, high-precision 2D and 3D parts, such as those found in the communications, aerospace, medical, and dental industries.
  • Operates on single- or three-phase power
  • Ultra-compact footprint
  • 20-pocket tool changer
  • 30,000-rpm spindle
See Available Stock
Current Lead Time
  • 20 Taper
  • 3 Axis
  • 30k RPM
  • 20 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
Compare Machines
BUILD & PRICE
Contact Distributor
  • Build-&-Price
  • Specs
  • Machine Info
  • Rotary Fit chart
Travels S.A.E METRIC
X Axis 12.00 in 305 mm
Y Axis 10.00 in 254 mm
Z Axis 14.00 in 356 mm
Spindle Nose to Table (~ max) 16.6 in 422 mm
Spindle Nose to Table (~ min) 2.6 in 66 mm
Spindle S.A.E METRIC
Max Rating 5.0 hp 3.7 kW
Max Speed 30000 rpm 30000 rpm
Max Torque 8.0 ft-lbf @ 3000 rpm 10.8 Nm @ 3000 rpm
Drive System Direct Speed, Belt Drive Direct Speed, Belt Drive
Taper ISO 20 ISO 20
Bearing Lubrication Air / Oil Injection Air / Oil Injection
Cooling Air Cooled Air Cooled
Table S.A.E METRIC
Length 22.5 in 572 mm
Width 10.0 in 254 mm
T-Slot Width 0.438 in to 0.440 in 11.13 mm to 11.18 mm
T-Slot Center Distance 3.38 in 86 mm
Number of Std T-Slots 3 3
Max Weight on Table (evenly distributed) 150 lb 68 kg
Feedrates S.A.E METRIC
Max Cutting 500 ipm 12.7 m/min
Rapids on X 757 ipm 19.2 m/min
Rapids on Y 757 ipm 19.2 m/min
Rapids on Z 757 ipm 19.2 m/min
Axis Motors S.A.E METRIC
Max Thrust X 1149 lbf 5111 N
Max Thrust Y 1149 lbf 5111 N
Max Thrust Z 1149 lbf 5111 N
Tool Changer S.A.E METRIC
Type Carousel Carousel
Capacity 20 20
Max Tool Diameter (full)** 2.3 in 58 mm
Max Tool Weight 5.0 lb 2.3 kg
Tool-to-Tool (avg) 3.20 s 3.20 s
General S.A.E METRIC
Coolant Capacity 13 gal 49 L
Air Required† 1 scfm @ 100 psi 28.0 L/min @ 4.8 bar
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Spindle Speed 30000 rpm 30000 rpm
Spindle Power 5.0 hp 3.7 kW
Input AC Voltage (1 Phase) 220 VAC 220 VAC
Full Load Amps (1 Phase) 16 A 16 A
Full Load Amps (3 Phase) - Low 12 A 12 A
Domestic Pallet 78.0 in x 62.0 in x 92.0 in 199 cm x 157 cm x 234 cm
Export Pallet 78.0 in x 62.0 in x 92.0 in 199 cm x 157 cm x 234 cm
Weight 2200 lb 998.0 kg
NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
*Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
**Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
† Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
AVAILABLE OPTIONS
VIDEOS
CUSTOMER TESTIMONIALS
RELATED PRODUCTS
Standard Features
  • 30,000-rpm Spindle
  • 20-Pocket Carousel Tool Changer
  • Window Air Blast
  • 13-Gallon Coolant Tank
  • Control Widescreen Monitor
  • Ethernet Interface
  • Advanced Tool Management
  • Media Display M-Code; M130
  • HaasDrop
  • High-Speed Machining
  • Rigid Tapping
  • User-Definable Macros
  • Coordinate Rotation and Scaling
  • Stainless Steel Way Covers
  • Phone Charging Stand
Warranty
  • 1-Year Standard Warranty
Available Options
Automation Options
  • Installation Guide
  • Layout Drawing
  • Torque Chart
  • Operator’s Manual
  • CM Series Flyer
Videos
3 Easy Ways To Set Tool Offsets Using VPS
You might already know these shortcuts to getting your tool offsets entered more quickly, but if not, Andrew walks you through 3 simple ways to speed things up and save you a few precious minutes during job setup.
Haas Wireless Intuitive Probing System
With the Haas Wireless Intuitive Probing System (WIPS), you can set tool and work offsets in a fraction of the time. No more edge finders or slips of paper under the tool needed.
CM-1 and TRT70 Cutting Demo
The Compact Mill is our small-footprint, high-accuracy solution for prototyping and producing small, high-precision, 2D and 3D parts, like those found in the communications, aerospace, medical, and dental industries. Small enough to fit into most freight elevators, the CM-1 can easily be moved with a pallet jack or equipment dolly.
Display Pictures and Videos on Your Haas Control Using M130
With M130, you can display setup sheets, tool lists, work instructions, and even videos – all within your program. No more taping work instructions to the machine, or hand writing notes telling your operator how to load or inspect a part; put it all in your NC program!
METALART sieraden
“As a goldsmith who makes jewelry using machining techniques, I’m very satisfied with the arrival of the new Haas CM-1. The software and machine are very well coordinated. Thanks to the Haas CM-1, I am able to make something unique for our customers.”
– Joeri Dijkman, Goldsmith
RELATED PRODUCTS
COMPACT CHUCKER LATHE
Haas CL-1
CL-1
CNC Chucker Lathe with 1" bar capacity
  • 5C Nose Chuck Size
  • 1.0" Bar Capacity
  • 6k RPM
  • 5 hp Power
    CNY ONLY
Learn More Build & Price
LARGER WORK ENVELOPE
Haas DT-1
DT-1
CNC Drill/Tap Center with 20" x 16" x 15.5" travels
  • 30 Taper
  • 3 Axis
  • 10k RPM
  • 20+1 Tool Capacity
    CNY ONLY
COMPACT 40-TAPER
Haas Super Mini Mill
Super Mini Mill
Super-Speed Mini Vertical Mill with 16" x 14" x 15" travels
  • 40 Taper
  • 3 Axis
  • 10k RPM
  • 30+1 Tool Capacity
    CNY ONLY
TRT70 CM-1 POSITIVE FIT
HRT100 CM-1 POSITIVE FIT
Build & Price
Get Started
Need More Information?
