Haas VMC + Rotary
Product Image
GET QUOTE
DESIGNED TO WORK
TOGETHER
Your browser doesn't support HTML5 video.
5-AXIS SIMPLIFIED
  • ADD A ROTARY
  • VMC + ROTARY
  • 5-AXIS MACHINES
VMC + ROTARY + OPTIONS = READY TO GO
  • CM-1 + TRT70 = work cube up to 3"
    Adding the super compact TRT70 tilting rotary table to the CM-1 creates a high-precision, 5-axis package for machining small, intricate parts.
  • Haas VF-2SS + TR160 = work cube up to 10"
    Simultaneous 5-axis motion reduces the number of operations, cuts cycle times, and reduces the number of setups to increase accuracy and maintain conformity throughout a part run.
  • DT-2 + TRT100 = work cube up to 5"
    This high-speed, lean-style, 5-axis combination is perfect for producing complex, multi-sided small parts in volume.
  • VF-4 + TR200Y = work cube up to 8"
    The compact TR200Y is designed to mount along the Y-axis of the VF-4, leaving plenty of room on the table for vises and other fixtures.
    CNY ONLY
View Details | Get Quote
    CNY ONLY
    CNY ONLY
    CNY ONLY
“We bought the Haas UMC-750s because of the very attractive quality-to-price ratio. We make a lot of complex automotive parts, and needed five-axis machines that weren’t too expensive. The components tend to be big, so we purchased two Haas UMCs – one is running while the other is loading and unloading. They are arranged in a small cell, with one operator to run both.”
Alluminio Sammarinese
Stefano Ceccato | CEO | Alluminio Sammarinese
DON’T FEAR 5-AXIS EP. 1
In the first video of our “Don’t Fear 5-Axis” series, John Nelson explains why 5-axis machining is much simpler than it has ever been, and why any shop can be a 5-axis shop.
DON’T FEAR 5-AXIS EP. 2
In the second video of our “Don’t Fear 5-Axis” series, John Nelson explains how to choose your machine and rotary combination, and discusses which options you should consider adding to make the most of your machine and rotary.
DON’T FEAR 5-AXIS EP. 3
In the third video of our “Don’t Fear 5-Axis” series, John Nelson talks about setting up your rotary table or trunnion, and explains how the Haas DWO/TCPC feature makes 4th- and 5th-axis work simpler than ever.
SIMPLIFY 5-AXIS MACHINING WITH DWO/TCPC
Our powerful DWO/TCPC (Dynamic Work Offsets / Tool Center Point Control) feature lets you create your CAM program ahead of time, and then place the workholding and part anywhere on the table, with no need to repost your program!
“At the start, we wanted a five-axis machine to differentiate ourselves from three main competitors we had identified in the market. But we needed to find a good machine at a good price, and we couldn’t afford to buy a new one. A pre-owned Haas VF-2 with TR160 trunnion proved to be the ideal solution.”
KMP
Sébastien Korczak | Owner | KMP
Still have questions? Ask away. We’ll hit you back with the answers.
Be as specific as you like, so we can help you find the best 5-axis solution for your shop.
