10k Spindle, 40T, DC Series (10K-40T-IN-DC)
Product Image
GET QUOTE
10,000-rpm 40-Taper Spindle, DC Series
    CNY ONLY
Standard spindle for 40-taper DC Series
  • 10k Speed
  • 40 Taper
  • 15 hp Power
  • Inline Drive
  • Option Info
  • Torque Chart
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This high-performance inline spindle is the standard spindle for 40-taper DC Series machines, providing 10,000 rpm for high-speed milling. The inline direct-drive spindle is coupled directly to the motor to provide excellent surface finishes and greater thermal stability.
  • Durable and reliable inline spindle
  • Good overall performance on 3D surfacing applications
Service Documents
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Need More Information?
