G-code, M-code, and Setting
Service Home G234 Tool Center Point Control (TCPC) (Group 08)
G234 Tool Center Point Control (TCPC) lets a machine correctly run a contouring 4- or 5-axis program when the workpiece is not located in the exact location specified by the CAM-generated program. This eliminates the need to repost a program from the CAM system when the programmed and the actual workpiece locations are different.
VMT - G234 - Tool Center Point Control (TCPC)
G234 Tool Center Point Control (TCPC) is a software feature in the Haas CNC control that allows a machine to correctly run a contouring 4- or 5-axis program when the workpiece is not located in the exact location specified by a CAM-generated program.
This eliminates the need to repost a program from the CAM system when the programmed and the actual workpiece locations are different. The Haas CNC control combines the known centers of rotation for the rotary axes (MRZP) and the location of the workpiece (e.g., active work offset G54) into a coordinate system.
TCPC makes sure that this coordinate system remains fixed relative to the table; when the rotary axes rotate, the linear coordinate system rotates with them. Like any other work setup, the workpiece must have a work offset applied to it. This tells the Haas CNC control where the workpiece is located on the machine table.
TCPC is activated with G234. G234cancels the previous H-code. An H-code must therefore be placed on the same block as G234. G234is canceled by G49, G42, and G44.
NOTE
The rotary axes must be at 0 before commanding G234 .
TCPC G-code is programmed from the tool tip. The control knows the centers of rotation for the rotary axes (MRZP), the location of the workpiece (active work offset), and the tool length offset. The control uses this data to calculate the position of tool tip relative to the active work offset and maintains a static tool tip position through rotary feed moves.
NOTE
Tool tip position is not maintained during rapid rotary moves. Do not program rapid moves while TCPC is active.
G234 Programmer s Notes
These key presses and program codes cancel G234:
  • [EMERGENCY STOP]
  • [RESET]
  • [HANDLE JOG]
  • [LIST PROGRAM]
  • M02 -- Program End
  • M30 -- Program End and Reset
  • G43 -- Tool Length Compensation +
  • G49 -- G43 / G44 / G143 Cancel
These codes will NOT cancel G234:
  • M00 -- Program Stop
  • M01 -- Optional Stop
These key presses and program codes impact G234:
  • G234 invokes TCPC and cancels G43.
  • When using tool length compensation, either G43 or G234 must be active. G43 and G234 cannot be active at the same time.
  • G234 cancels the previous H-code. An H-code must therefore be placed on the same block as G234.
  • G234 cannot be used at the same time as G254 (DWO).
These codes ignore 234:
  • G28 -- Return to Machine Zero Through Optional Reference Point
  • G29 -- Move to Location Thru G29 Reference Point
  • G53 -- Non-Modal Machine Coordinate Selection
  • M06 -- Tool Change
Invoking G234 (TCPC) rotates the work envelope. If the position is close to the travel limits, the rotation can put the current work position outside of travel limits and cause an over travel alarm. To solve this, command the machine to the center of the work offset (or near the center of the table on a UMC), and then invoke G234 (TCPC).
G234 (TCPC) is intended for simultaneous 4- and 5-axis contouring programs. An active work offset (G54, G55, etc.) is required to use G234.
