G-code, M-code, and Setting
Service Home 34 - 4th Axis Diameter
This is used to set the diameter of the 4th axis, which the control uses to determine the angular feedrate. The feedrate in a program is always inches or millimeters per minute ( G94); therefore, the control must know the diameter of the part being machined in the 4th axis in order to compute angular feedrate. Refer to Setting 79 for information on the 5th axis diameter setting.
