    2. Español - México
    3. 한국어
    4. Українська
    2. Español - México
    3. 한국어
    4. Українська
1000 Blocks Per Second Calculator - Instructions
Service Home How To Procedures 1000 Blocks Per Second Calculator - Instructions
Recently Updated Last updated: 04/09/2021
- Jump to Section - 1. Instructions 2. Instructions (3 steps) Back to Top
Instructions
Use the 1000 blocks per second (BPS) calculator program to analyze G-code programs to determine if they violate the 1000 BPS limit.
Instructions
Download the 1000 Block Per Second Calulator Program
Note: Make sure you unzip the file.
Run the BlocksPerSecond - Angle Calculator.exe . Check the BPS Calculator [1] radio button. Enter 1000 in the Enter Max BPS Limit [2] box. Check the Filter [3] box. Check the Put output file in same directory as input file [4] box.
Click the Click to choose input file [1] box. Select the G-code program you want to inspect. Click the Calculate [2] button.
A report [1] of the lines exceeding the maximum BPS per second is generated. The report (xxxxxx_out_filtered.txt) file is saved in the same folder as the input file.
