Coolant Pump - 3/4hp - Start Capacitor - Replacement - AD0550
Service Home How To Procedures Alarm Search: 4.103 Coolant Pump - 3/4hp - Start Capacitor - Replacement - AD0550
- Jump to Section - 1. Introduction 2. Capacitor Verification (2 steps) 3. Replacement Back to Top
Recently Updated Last updated: 01/16/2025
AD0550
This procedure tells you how to replace the start capacitor in an A-Ryung 3/4hp coolant pump.
Use this procedure after troubleshooting the coolant pump and determining that the capacitor has failed. Refer to Standard Coolant - Troubleshooting Guide - NGC.
This procedure applies to the following part numbers:
  • 93-3364 START CAPACITOR ARYUNG 3/4HP SERVICE KIT
Required tools and parts  :
  • Multimeter with capacitance reading capabilities
  • Capacitance meter (optional)
Note : Refer to the verification section below to confirm that the capacitor is defective.
Remove start capacitor cover [1] from the coolant pump [2].
Unplug the spade connectors to the capacitor.
Note : Visually inspect for any corrosion or leakage from the capacitor.
Danger : Ensure that the capacitor is safely discharged before continuing.
Measure the capacitance of the capacitor using a multimeter set to capacitance mode or using a capacitance meter.
Note : To verify if the capacitor is faulty refer to the capacity marked on it and measure to confirm that value. The capacity is measured in μF.
If the capacitor reading is found to be within specification then the fault must be in other parts of the system. Clean the capacitor and spade connectors from any debris or corrosion and re-assemble the pump to test it. Ensure that the spade have a tight fit for a secure connection by gently squeezing them with a pair of pliers.
Refer back to Standard Coolant - Troubleshooting Guide - NGC if the capacitor was within specification.
Replacement
Cut the foam tape [1] into two even pieces to attach to the new capacitor as shown. Install the new capacitor where the old one was removed from and reattach the cover to the coolant pump.
Important : Ensure that the foam tape is applied because it reduces the vibrations transmitted to the capacitor.
