Side-Mount Tool Changer - Carousel Motor - Replacement - AD0362
Service Home How To Procedures Side-Mount Tool Changer - Carousel Motor - Replacement - AD0362
Recently Updated Last updated: 11/30/2018
AD0362
Applies to machines built from: July, 1998
- Jump to Section - 1. Parts Required 2. Remove/Replace Motor (3 steps) Back to Top
Parts Required
This procedure applies to several kits. You need only (1) of the motors listed here:
  • 93-30-2111 Motor, SMTC Carousel 40T
  • 93-1642 Motor, SMTC Carousel 30/40T
  • 93-1664 Motor, SMTC Carousel 50T
Remove the carousel cover assembly.
Disconnect the motor cable [1] from the electrical connector bracket.
Remove the (2) motor mount screws [2], the belt [3], and the used motor.
Install the new motor with the (2) motor mount screws [2].
Tighten the screws, but leave them loose enough to control the adjustment of the belt.
Put the new belt around the tool changer sprocket and the motor sprocket.
Tighten the belt until it has no more than 1/8 inch (3 mm) of deflection.
Torque the motor mount place screws [2] to 15 ft-lb (20.34 Nm).
Connect the motor cable [1] at the electrical connector bracket.
Replace the carousel cover assembly.
