      • Rotary Workholding Kits
Haas Automatic Parts Loader (APL) - Fence Installation - AD0553
Service Home How To Procedures Alarm Search: 174 Haas Automatic Parts Loader (APL) - Fence Installation - AD0553
6.1 APL - Fence Installation
Recently Updated Last updated: 10/15/2021
AD0553
This procedure tells you how to install the APL Fence and the fence interlock.
Note: The  REMOTE JOG HANDLE - XL (PN 93-1000610) is required for VMC and lathe APLs with a fence.
  • 93-3362: INTERLOCK REPLACEMENT KIT APL
  • 93-3363: INTERLOCK REPLACEMENT KIT HRP
  • 93-3303: REPLACEMENT INTERLOCK HRP 28'
  • 93-3302: REPLACEMENT INTERLOCK HRP 36'
  • 93-3301: REPLACEMENT INTERLOCK HRP 49'
  • 93-3299: REPLACEMENT INTERLOCK LATHE APL 33'
  • 93-3277: REPLACEMENT INTERLOCK VMC APL 19'
  • 93-1000557: APL CE FENCE KIT ST 20/25
  • 93-1000556: APL CE FENCE KIT ST 10/15
  • 93-1000709: FENCE KIT APL ST-10/15 CE
  • 93-1000710: FENCE KIT APL ST-20/25 CE
  • 93-1000711: FENCE KIT APL VMC CE
  • 93-1001007: APL INSTALL KIT UMC-500/SS CE
  • 30-12991A: INSTALL KIT APL ST-10/15 CE
  • 30-12992A: INSTALL KIT APL ST-20/25 CE
  • 30-12993A: INSTALL KIT APL SML VF CE
  • 30-12995: APL CE KIT UMC-500
Installation Guide
Follow the directions below to assemble the fence.
Once the fence is assembled, attach the Fence Safety decal plates using the screws, nuts, and mounting plates as shown.
The Fence Safety decal location is to the left of the interlock, 4 inches from the right of the fence [1] and 34 inches from the top of the door [2].
Insert the bumper [1] into the cutout on the fence bumper bracket [2] using pliers for help as needed.
Install the fence bumper bracket [2] on top of the door stop bracket [3].
Fence Installation to Mill APL
Assemble the fence around the machine as shown. Make sure the door [1] opens and closes correctly.
Fence Installation to Lathe APL
For ST-10
Install the fence panel sheet metal [1] to the machine sheet metal and secure the APL fence to the fence panel sheet metal.
For ST-20/25
Fence Installation to UMC APL
Refer to this step for APL's built before January 2024
The door opening [2] is about 70 inches (1778mm) wide and the width of the back of the fence [3] is about 114.125 inches (2899mm).
Refer to this step for CE/Fence APL's built January 2024 and later
The door opening [2] is about 48 inches (1219mm) wide and the width of the back of the fence [3] is about 76.0625 inches (1932mm).
Install the fence panel sheet metal [1] to the machine sheet metal and secure the APL fence [2] to the fence panel sheet metal.
Interlock Installation
Fortress Interlock 1
Mount the interlock mount to the fence post using self tapping screws.
Mount the interlock to the mount and install the interlock door mount to the fence door.
If the fence includes a handle, mount the handle to the door.
Fortress Interlock 2
Follow the insctructions below for the fortress interlock 2.
Skorpion Interlock
Mount the interlock handle bracket, interlock key, and handle to the door.
Mount the interlock to the interlock bracket
Mount the interlock and interlock bracket to the fence post bracket.
Route the interlock wire to the I/O Board and connect it to P1 and P9.
Note: This image shows the Fortress Interlock 1, but the I/O board wiring will be the same for all interlock versions.
For VFs, route the interlock wire to the control box as shown.
For lathes, route the interlock wire to the control box as shown.
For UMC, route the interlock wire under the the fence and along the skirt of the machine to the control box.
Note: Use cable clamp magnets to run the wire along the skirt of the machine.
Interlock Verification
With the key inserted in the interlock, the two red LED lights in the front of the interlock should be off [1].
On the Haas pendant, there should not be any E-stop or light curtain/fence alarms or icon triggered.
Remove the key from the interlock. The two red LED lights should turn on [2] and a warning should appear on the Haas pendant for light curtain/fence.
Remote Jog Handle Box - Installation
For Mills
Install the Remote Jog Handle Box [1] as shown using the provided mounting magnets.
Then route the cable from the box to the pendant as shown.
For Lathes
Install the Remotoe Jog Handle Box [1] to the APL fence using the provided hardware.
Route the cable to the pendant as shown .
Wiring Diagram
Connect the remote jog handle wire to P9 on the SKBIF in the pendant.
Remove the jumpers [1] on the SKBIF from the horizontal position and replace them in the vertical position.
 WARNING: By not putting the jumpers in the vertical position, E-STOP functionality on the RJH-XL is disabled and the machine is considered unsafe.  Jumpers MUST be inserted vertically.
Remote E-Stop Verification
Press the Pendant and RJH-XL E-STOP buttons and make sure the machine generates 107 EMERGENCY STOP alarm. If the E-STOP button does not generate a 107 EMERGENCY STOP alarm verify the wiring. Load the latest configuration files to enable the RJH-XL.
 Warning: By not putting the jumpers in the vertical position, E-STOP functionality on the RJH-XL is disabled and the machine is considered unsafe. Jumpers MUST be inserted vertically.
