BMT65/75 Gearbox - ACME Tailstock - Haas Liquid Grease (HLG) - Refill Procedure - AD0639
Service Home How To Procedures BMT65/75 Gearbox - ACME Tailstock - Haas Liquid Grease (HLG) - Refill Procedure - AD0639
Recently Updated Last updated: 11/30/2023
BMT Gearbox - ACME Tailstock - Haas Liquid Grease (HLG) - Refill Procedure
AD0639
- Jump to Section - 1. Introduction 2. BMT45 Gearbox - HLG Refill (1 step) 3. BMT65 & BMT75 Gearbox - HLG Refill (1 step) 4. ACME Tailstock Reservoir - HLG Refill (1 step) Back to Top
This service kit and document shows you how to refill a BMT Gearbox Housing or ACME Tailstock Reservoir with Haas Liquid Grease.
  • 93-3599 HAAS LIQUID GREASE REFILL KIT 1 GALLON
Refill 1.0 quart of Haas Liquid Grease through the turret gearbox muffler hole. The location of the muffler is dependent on the machine build date.
Muffler located on gearbox housing back cover[1].
Muffler located above turret clamp/unclamp port locations[2].
For BMT65 Gearbox Housings:
Refill the liquid grease through the turret indexer motor mounting hole [1].
  • If machine is equipped with the live tooling, fill the turret gearbox with 2 quarts of Haas Liquid Grease.
  • If machine is not equipped with the live tooling, fill the turret gearbox with 3 quarts of the Haas Liquid Grease.
For ACME Tailstock Reservoirs:
Refill the liquid grease to the upper fill line[1].
