    2. Українська
    2. Українська
Hydraulic Tailstock Check Valve Eliminator - Installation - AD0410
Service Home How To Procedures Hydraulic Tailstock Check Valve Eliminator - Installation
Recently Updated Last updated: 04/03/2020
AD0410
- Jump to Section - 1. Introduction 2. Installation (1 step) Back to Top
Applies to Machines Built 8/2015-9/2018
P/N 93-2879 TAILSTOCK CHECK VALVE ELIMINATOR KIT.
Under certain conditions when using a low tailstock pressure setting, the hydraulic tailstock can get stuck at home position.
Replacing the dual piloted check valve [1] with the check valve eliminator will eliminate this issue. The dual piloted check valve [1] can be found on the left side of the hydraulic manifold [2] that is located above the hydraulic power unit (HPU).
Power the machine OFF
Remove the nut [1], coils [2] and the spacer [3] from the tailstock solenoid to gain access to the tailstock check valve [4].
Attention: Note the position and orientation of the solenoid coils [2] and the spacer [3].
Remove the tailstock check valve [4] from the HPU manifold and replace with the check valve eliminator [5].
Torque the check valve eliminator to 20 ft-lbs.
Install the solenoid coils [2] and the spacer [3] onto the tailstock solenoid and torque the coil locknut [1] and torque it to 4 ft-lbs.
Note: The tailstock behaviour will change after removing the check valve. When the HPU is turned OFF the tailstock will deflect when pushed by hand
