    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • VF-2SS
      • VF-2SSYT + Pallet Pool
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Haas Tooling
      Haas Tooling View All
      Inventory Sale Inventory Sale Mill Toolholding Mill Workholding Tombstones Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle Winner's Circle
    • All Sale Items
      All Sale Items Shop All
      • Drill Chucks
      • Pull Studs
      • Burrs
      • Fixed Jaw Vises
      • Reduction Sleeves
      • Cut-Off Tooling
      • Threading Toolholders
      • Small ID Grooving & Threading Tools
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • Mill Toolholding Kits
    • Inventory Sale
      Inventory Sale Shop All
      • Drill Chucks
      • Pull Studs
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • CNC Clearing Fans
      • Spare Parts
      • Lathe Tooling Kits
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
    • Deals Of The Week
      Deals Of The Week Shop All
      • Grooving Tools
      • Cut-Off Tooling
      • Boring Bars
      • OD Toolholders
    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
Restore Machine - NGC
Service Home How To Procedures Restore Machine - NGC
Recently Updated Last updated: 02/08/2021
Tools Required
  • USB Memory Device
Set Setting 155, Load Pocket Tables, to ON.
 Note: Make sure the memory lock key switch is in the unlocked position.
Push [LIST PROGRAM].
Navigate to the USB tab [1].
Select the HaasBackup (xx-xx-xxxx).zip file [2].
Push [ENTER] to put a mark in the box.
Push [F4], System [3].
Select Restore Machine [4].
Push [ENTER].
Push [EMERGENCY STOP].
 Note: User Data and Memory will be erased before a restore if the backup includes User Data and Programs.
Push [ENTER] to select and deselect what you must restore.
Push [F4] to restore the machine.
 Note: Alarms after the machine restore are normal. Continue the procedure.
Power off and power on the machine.
Set Setting 155, Load Pocket Tables, to OFF.
  • Make sure that the customer's rotary configurations are correct. Refer to: NGC- EC-1600, UMC-750 Rotary Parameter Identification
  • Make sure the pocket table is correct
  • Make sure the work / tool offsets loaded
  • Zero Return All Axes
  • Test the tool changer
  • Test the spindle RPM
  • Test coolant operation
  • Test the chip auger
  • Calibrate the probe. Refer to: Next Generation Control - Probe Calibration (VPS)
  • Test the remote jog handle
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
