      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
ST-10/15 Tool Changer Gearbox - Oil Shield - Installation - AD0635
Service Home How To Procedures ST-10/15 Tool Changer Gearbox - Oil Shield - Installation - AD0635
Recently Updated Last updated: 02/28/2023
AD0635
- Jump to Section - 1. Introduction 2. Oil Shield Installation (2 steps) Back to Top
This procedure will show you how to install a oil shield to a ST-10/15 tool changer gearbox.  This oil shield will prevent oil from being pushed back into the air cylinder.
This document and service kit applies to the following part number:
  • 25-16129 - DEFLECTOR TURRET CLAMP CYLINDER ST-10
Jog the Z-Axis towards the main spindle as much as possible.  Be careful when you jog the turret as tools in the turret can hit objects.
Remove the Tool Changer Gearbox End Cover [1].
Remove the Tool Changer Gearbox Main Cover [2]
Remove the two 10-32 SHCS screws [1] from the air cylinder.
Install the Oil Shield bracket [2] as shown using the same 10-32 SHCS screws.
Re-install the covers.
