    2. Español - España
    3. Español - México
    26. Українська
    2. Español - España
    3. Español - México
    26. Українська
UMC-750 - Shim Kit Checklist - 93-2236 - AD0131
Service Home How To Procedures UMC-750 - Shim Kit Checklist - 93-2236 - AD0131
8.5 UMC-750 - Shim Kit Checklist
Recently Updated Last updated: 02/26/2021
AD0131
This is the Shim Kit Checklist for the following kit:
  • 93-2236 LOANER, SHIM KIT FOR UMC-750
Checklist: Shim-Spacer-Column
Thickness Part # Quantity in kit USED
.02100 20-9358A 2
0.2105 20-9359A 2
.02110 20-9383A 2
0.2115 20-9365A 2
0.2120 20-9384A 2
0.2125 20-9385A 2
0.2130 20-9368A 2
0.2135 20-9369A 2
0.2140 20-9386A 2
0.2145 20-9371A 2
0.2150 20-9372A 2
0.2155 20-9387A 2
0.2160 20-9374A 2
0.2165 20-9375A 2
0.2170 20-9376A 2
0.2175 20-9377A 2
0.2180 20-9378A 2
0.2185 20-9379A 2
0.2190 20-9380A 2
0.2195 20-9381A 2
0.2200 20-9382A 2
Note: Kit Owners Only: Specify the shim thickness when you order replacements. For example, 20-9382 0.2145
Checklist: Horshoe Shims
0.0010 59-0240 2
0.0020 59-0241 2
0.0030 59-0242 2
Checklist: Shim-Spacer-Column-Large
0.2130 20-6282A 2
0.2135 20-6283A 2
0.2140 20-6284A 2
0.2145 20-6285A 2
0.2150 20-6286A 2
0.2155 20-6287A 2
0.2160 20-6288A 2
0.2165 20-6289A 2
0.2170 20-6290A
0.2175 20-6291A 2
0.2180 20-6294A 2
0.2185 20-6295A 2
0.2190 20-6292A 2
0.2195 20-6293A 2
0.2200 20-6296A 2
0.2205 20-6297A 2
0.2210 20-6277A 2
0.2215 20-6279A 2
0.2220 20-6278A 2
0.2225 20-6298A 2
0.2230 20-6281A 2
Note: Kit Owners Only: Specify the shim thickness when you order replacements. For example, 20-6290A 0.2080
RECORD WHICH SHIMS WERE REMOVED FROM THE KIT IN THE USED COLUMN.
RETURN THE CHECK LIST WITH THE SHIM KIT.
RETURN THE ORIGINAL SHIMS IN THE CRATE.
