UMC-750 Gas Spring Counterbalance Replacement - AD0582
Service Home How To Procedures Alarm Search: 9918 UMC-750 Gas Spring Counterbalance Replacement - AD0582
Recently Updated Last updated: 11/15/2021
AD0582
Under Construction
- Jump to Section - 1. Introduction 2. UMC-750 Gas Spring Counterbalance - Removal (4 steps) 3. UMC-750 Gas Spring Counterbalance Installation (3 steps) Back to Top
This procedure outlines how to the replace gas-spring counterbalance on UMC-750 / 750P.
This procedure applies to the following service kits:
  • 93-2635 720LB GAS SPRING SERVICE KIT
You should not do mechanical or electrical machine repairs or service procedures unless you are qualified and knowledgeable about the processes.
  Only authorized personnel with the proper training and certification should do this repair procedure.
  All information herein is provided as a courtesy for Haas machine owners for reference and illustrative purposes only. Haas Automation cannot be held responsible for repairs you perform. Only those services and repairs that are provided by authorized Haas Factory Outlet distributors are guaranteed.
Change Setting 7, PARAMETER LOCK, to OFF.
Set Setting 53, Jog w/o Zero Return, [1] to ON.
Set Parameter 151:20, B Axis CK TRAVL LIM, [2] to 0.
Jog the Z Axis to the end of travel in the postive (+) direction.
Remove the rear-center panel.
Jog the B Axis [1] 135 degrees in the positive (+) direction.
The gas-spring counterbalance is fully extended.
If the gas-spring counterbalance is not fully extended, do this step:
Note: Use the remote jog handle to slowly jog the B Axis in the positive (+) direction. Jog the B Axis until the gas-spring counterbalance is fully extended.
Caution: Slowly jog the B Aixs to make sure the gas-spring counterbalance [2] does not cause damage to the central conduit [3].
Press EMERGENCY STOP.
Press POWER OFF.
Turn off, then Lockout /Tagout the main circuit breaker.
Remove the gas-spring counterbalance [1].
Note: For clarity, the illustration does not show the conduit and the conduit support-bracket. The removal of the conduit and conduit support-bracket is not necessary.
Apply medium-strength thread locking compound [1] to the (2) gas-spring counterbalance screws.
Install the gas-spring counterbalance [2] .
Torque [3] the gas-spring counterbalance screws to 110 ft-lb (149 Nm).
Unlock and power on the main circuit breaker.
Press POWER ON.
Set Setting 7, PARAMETER LOCK, to OFF.
Set Parameter 151:20, B Axis CK TRAVL LIM, [2] to 1.
Jog the B axis in the negative (-) direction to the zero position.
Caution: To prevent damage to the central conduit, do not press ZERO RETURN for this step.
Install the rear-center panel.
