      • Rotary Workholding Kits
Side-Mount Tool Changer - Double Arm - Alignment - VMC
Service Home How To Procedures Alarm Search: 9959 Side-Mount Tool Changer - Double Arm - Alignment - VMC
- Jump to Section - 1. How to Align a Side Mount Tool Changer Video 2. Introduction 3. SMTC Double Arm Replacement Verification 4. Double Arm - Alignment (5 steps) Back to Top
Recently Updated Last updated: 04/28/2025
SMTC - Double Arm - Alignment - VMC
Applies to machines built from: November, 2013
Revision A - 4/2025
The following service video shows you how to align a side mount tool changer.
Note: This service video is for reference only and does not replace the written procedure.
This procedure shows you how to align the double arm on a machine with a side-mount tool changer (SMTC).
Tools Required:
  • T-2108 SMTC Arm Alignment Tool
  • T-2086 CT-40 Alignment Split Tool
  • T-2089 CT-50 Alignment Split Tool
  • T-2088 BT-50 Alignment Split Tool
  • Haas Control Key (NGC Control only)
If the machine is replacing a double arm it is important to verify the following  items in this section to make sure the double arm can be aligned properly.
NOTE: The same verification steps will apply to machined [1] and casted [2] double arm replacements.Some machines may still received machined [1] double arm replacements. Use the image below as reference.
Verify the double arm length
Check that the replacement double arm [2] is the correct length, measure from the center to center of the tool holder flange between the original [1] and replacement double arm [2].
Verify that the double arm is the correct taper size and type
To differentiate between the BT, CT, and HSK verify that the BT V-flange is as shown in image [1] and the CT V-flange is as shown in image [2], and the HSK V-flange is as shown in image [3].
Verify that the double arm has the correct key slot offset
Now the casted double arm will have the key slot machined in a 0 degree angle position [1] or at a 2.5 degree angled position [2], both double arms will use only a straight key instead of an offset key.
HSG - 7/5/2023
Make sure that the taper lock [4] is sufficiently tight to prevent the double arm from falling off the shaft, but loose enough to rotate the double arm on the shaft.
Classic Haas Control (CHC)
  1. Go into DEBUG mode. Go into RECOVERY mode. Select the MANUAL TOOL CHANGER OPERATION mode.
Next Generation Control (NGC)
  1. Insert the Haas Control Key. If necessary cycle power.
  2. Go into RECOVERY mode. Select the MANUAL TOOL CHANGER OPERATION mode.
Push [ATC FWD] until ARM at CL/UNCL has a value of 1. Manually rotate the double arm [3] on the cambox output shaft to be parallel with the Y Axis.
Push [EMERGENCY STOP]. Clear alarms.
Put a tool holder [2] with no cutter into the pocket [1].
Manually turn the double arm [2] on the shaft so the slide [4] slightly touches the tool holder [1].
Use a caliper [3] to measure the height between the bottom of the V Flange and the double arm.
Manually turn the double arm on the shaft so the arm engages the tool holder.
Use a caliper to measure the height between the bottom of the V Flange and the double arm.
If the measurement is different, then adjust the height of the arm and repeat this step. Use the T-2108 tool to adjust the double arm height. When the measurement is the same, record the measurement.
Manually turn the double arm until you can remove the tool holder.
Put the bottom part [1] of an alignment split tool into the arm [4] near the pocket. Install the top part [2] of an alignment split tool into the pocket [3].
Align the split tools.
Put the pin [5] for the alignment split tool into the top and bottom parts to perform an alignment check.
Remove the pin.
Lightly tighten the clamp screws 1/4 turn. Tighten the screws [1] in a star pattern. Perform an alignment check [2] each time you tighten all the screws. Repeat this process until the screws tightly hold the double arm.
Remove the T-2108 tool [3].
Torque the screws in the star pattern to the correct ft-lbs below.
 Note: You must repeat this action a number of times to make sure the screws are torqued to the correct ft-lbs.
  • 8-Screw Double-Arm - 15 ft-lb (20 Nm)
  • 6-Screw Double-Arm - 20 ft-lb (28 Nm)
Push [ATC REV] until you can safely remove the tool from the pocket.
Remove both parts of the alignment split tool.
After all of the screws are torqued verify the double arm height alignment in Step 2.
Release the [EMERGENCY STOP].
For a VMC refer to these procedures:
Classic Haas Control:
  • VMC - Side-Mount Tool Changer - Set Parameter 64 - Z Axis Tool Change Offset
  • VMC - Side-Mount Tool Changer - Parameter 257 - Spindle Orientation Offset
Next Generation Control:
  • Side-Mount Tool Changer - Z Axis Tool Change Offset
  • Side-Mount Tool Changer - 40T/50T Spindle Orientation Offset
  • Side-Mount Tool Changer - HSK - Spindle Orientation Offset - NGC
