VMC - X/Y Servo Motor Seal - Installation - AD0790
Service Home How To Procedures VMC - X/Y Servo Motor Seal - Installation - AD0790
Recently Updated Last updated: 08/09/2024
AD0790
- Jump to Section - 1. Introduction 2. Installation (2 steps) Back to Top
This procedure will tell you how to install a servo motor seal on a VMC X or Y-axis servo motor.  We recommend to use this procedure if you are replacing the servo motor to prevent future coolant intrusion or damage. Refer to Servo Motor Mount Cover - Replacement  to also prevent coolant intrusion in the motor.
 Important: This motor seal ONLY works on Yaskawa servo motors size 09, 13, and 20.
Note: Refer to VMC - X/Y - Axis Servo Motor - Replacement  to remove servo motor from the machine if needed.
This procedure applies the following kits/part:
  • 20-10911 Motor Seal  X/Y-Axis Delrin
  • 93-3827 Bscrew 32mm MTR CVR SVC KIT S VF Y-AX
  • 93-3828 Bscrew 32mm MTR CVR SVC KIT S VF X-AX
Align the motor seal [1] concentricly to the output shaft of the servo motor [2]. Make sure that the side with a chamfer [3] on the outer and inner diameter is facing toward the motor.
Push the seal [1] onto the shaft. Make sure seal is seated all the way down onto the motor.
IR11-11UN Carbide Threading Insert, Grade HU35T - Pack of 10 $146.95 $124.97
