    3. Español
    13. Русский
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • 5% off + saving on Automation
      • VF-2SS
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      • video-test-page
      Mill Toolholding Mill Workholding Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
    3. Español
    13. Русский
Search
Window Blast - Installation - AD0430
Service Home How To Procedures Window Blast - Installation - AD0430
Recently Updated Last updated: 01/11/2019
- Jump to Section - 1. Machine Compatibility 2. Document Applies to these Parts 3. Window Blast - Installation (1 step) Back to Top
  • Vertical Mills except for DT, DM, and TM
  • Chucker Lathes
KIT: P/N 93-1000008 QTY: 1
Select a location on a door to mount the Window Blast.
  • Make sure the Window Blast will have adequate clearance on the inside of the machine across the door's full range of motion.
  • The window blast hole must be located at least 0.6 inches on center from any seams, ridges, or overlaps in the door sheet metal.
  • When locating the window blast above the door handle on a vertical mill, angle the tip approximately 10 dgrees down from horizontal.
Drill a 1/2 inch diameter hole through the door in your selected location.
Assemble the Window Blast as shown.
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
