      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
Counterbalance Pressure Chart
Recently Updated Last updated: 03/21/2025
Counterbalance - Pressure Chart
This chart shows the correct pressures for the counterbalance tank. Measure the pressure at the top of Z-Axis travel for VMCs and at the top of Y-Axis travel for HMCs. Pressure that is 50 psi (3 bar) higher than the value in the chart is permitted. But pressure that is lower than the value in the chart is not permitted.
VMC - Counterbalance Pressures
Model Made After Pressure Made After Pressure Made After Pressure
- - PSI BAR - PSI BAR - PSI BAR
VF-O/OE/EXT/1/2 (VCE 475/500/550/700/750) 4/28/1995 750 52 - - - - - -
VF-3/4 (VCE 1000/1250) 4/28/1995 1150 79 - - - - - -
VF-5 XRT 10/8/2004 750 52 - - - - - -
VF-5, VM-3, VF-3YT (VCE 1300) 7/21/1998 950 66 10/14/1998 875 60 - - -
VF-5/50, VF-3YT/50 (VCE 1300) 7/21/1998 1100 76 - - - - - -
VF-6/7/10/12 - 50 (VCE 1600, 2000, 3000) 10/30/1997 1150 79 - - - - - -
VF-6/7/10/12 (VCE 1600, 2000, 3000) 10/30/1997 750 52 - - - - - -
VF-8/9/11 - 50 (VCE 1600, 2000, 3000) 7/21/1998 1550 107 - - - - - -
VF-8/9/11 (VCE 1600W, 2000W, 3000W) 10/30/1997 750 52 - - - - - -
VR-8/9/11 10/30/1997 1800 124 7/21/1998 1100 76 10/14/1998 1025 71
VS-1/2/3 2/29/2000 1250 86 - - - - - -
VS-1/3 1/1/2021 750 52 - - - - - -
HDC-3-5AX 12/1/2022 1050 72 - - - - - -
VTC 5/4/2002 1150 79 - - - - - -
HMC - Counterbalance Pressures
EC-1600/2000/3000 3/15/2004 1000 70 9/13/2004 550 38 6/14/2005 800 55
EC-630 3/21/2006 800 55 - - - - - -
HS-1 10/30/1997 600 51 - - - - - -
HS-3/4/7 6/5/1998 1150 79 6/18/1999 1200 83 2/29/2000 1250 86
