VMC Maintenance Schedule - RD0080
Service Home VMC Maintenance Schedule - RD0080
Recently Updated Last updated: 10/17/2025
RD0080
Revision B - 5/2025
- Jump to Section - 1. Introduction Back to Top
Keep your Haas machines running at peak performance while avoiding unplanned downtime. A maintenance program allows you to manage your schedule rather than getting caught with untimely surprises. This page shows the recommended maintenance intervals.
Maintenance Item Interval
Clean debris from the APC and Receiver areas.
Weekly
Clean debris from receiver pallet clamped switch.
Weekly
Grease the plunger.
Weekly
Clean the locating pins and bushings.
Weekly
Inspect the pallet wipers.
Monthly
Inspect the door for proper operation.
Monthly
Grease the door side guide rails.
Monthly
Automatic Tool Changer - SMTC
Clean the chips from the tool changer.
Weekly
Inspect the arm plunger and adjuster assembly.
Six Months
Clean and lubricate the pocket tool plungers.
Six Months
Clean and lubricate the track on the carousel housing that the tool pocket rollers ride on (SMTC30/50 only).
Six Months
Grease the tool changer cams.
Annually
Inspect and replace worn pocket components: springs, plungers (BT30 have a spring leaf).
Annually
Inspect the oil level in the cambox. Quarterly
Automatic Tool Changer - Umbrella
Weekly
Inspect motors and mechanical sensors.
Monthly
Inspect motors and proximity sensors.
Monthly
Grease the guide rails.
Monthly
Grease the extractor fingers.
Monthly
Replace the filter bag.
Check the Gauge
Inspect the hoses for cracking.
Six Months
Axis Lubrication
Inspect oil reservoir level and refill.
Monthly
Six Months
Perform an Axis Lubrication Test. Six Months
Ballscrews/Linear guides equipped with zerk fitting Monthly or weekly if cutting absorbent materials
Inspect the counterbalance pressure.
Monthly
Clean vector drive air vents / filter.
Monthly
Inspect windows for damage.
Daily
Inspect the door interlock operation.
Daily
Inspect waycovers and lubricate.
Monthly
Gearbox
Inspect the oil level.
Monthly
50T Gearbox 16DP-C Clean the oil pump inlet screen.
Six Months
Replace the oil.
Annually
Minimum Quantity Lubrication
Clean the filter inside the oil reservoir.
Annually
Inspect the oil skimmer pickup tube.
Six Months
Pneumatics
Inspect the spindle air regulator pressure.
Weekly
Six Months
Clean the Air Purge Solenoid.
Annually
Probe System
Check the probe batteries.
Six Months
Check probe calibration.
Six Months
Annually
Replace the oil.
Two Years
Inspect the A-Axis counterbalance cylinder for oil leaks. Two Years
Replace the A-Axis counterbalance cylinder.
Four Years
Standard Coolant System
Clean the filter screen.
As Required
Inspect the coolant level.
Weekly
Inspect the coolant concentration. Fill out the Mixture - Maintenance Log sheet.
Weekly
Completely clean the coolant tank and replace the coolant.
Six Months
Clean the standard coolant filter.
Six Months
Verify coolant refill is operating correctly.
Six Months
Through Spindle Coolant (TSC) 300/1K PSI
Clean the TSC-300 / 1K Pump Filter
Six Months
Six Months
Verify the Auto Clean system is operating correctly.
Six Months
Spindle
Clean and lubricate the spindle taper.
As Required
Spindle drawbar force measurement.
Annually
Spindle Lubrication
Inspect lubrication tank level.
Monthly
Perform Spindle Lubrication Test.
Six Months
Tooling
Grease Pull Studs.
As Required
